SOURCE: Copystar CS-1810 Error Code
I have code c620 showing up on my copystar 1810. Anybody have an easy fix so I dont have to take in to shop.
SOURCE: SERVICE ERROR c7980
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
SOURCE: how to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
SOURCE: I have a copy Start CS 1650 with the error code
there is no C400 code, but there is a C4000 and its a pretty common code on these boxes. it's pointing to your laser unit. definetly not easy to get to. you will have to have laser unit replaced or sometimes i have had luck pulling out laser, pulling polygon mirror out and lubricating the shaft. that only works about 50-60% of time however and if you are paying a tech to do this work, you may just want to replace it as it is fairly time consuming to get laser out.
hth,
razors
Testimonial: "Thank you for your time and effort. I am the tech."
SOURCE: cs-2550 sofware
goto usa.copystar.com and search in downloads...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
