Kodak EasyShare CX7530 Digital Camera Logo
A
Anonymous Posted on Aug 29, 2005
Slow response time
Why does my digital camera have a slow response time when I press the shutter button?
Anonymous
Level 2:
Scholar:
  • Expert 114 Answers
  • Posted on Aug 29, 2005
Anonymous
Expert
Level 2:
Scholar:
Answers
114
Questions
0
Helped
35877
Points
342
Before a digital camera is ready to take a picture, the electronics inside the camera must get ready to capture the picture and save it to the memory card or the internal camera memory. Press the shutter button half-way (to its first detent) to set the exposure and focus. When the ready light is green, continue pressing the shutter button completely down to take the picture. The picture is taken almost immediately.
7helpful
2answers
The screen went white after/when I pressed the shutter button on my G11... sometimes it's ok, then it goes white again. What's wrong?
This is most often a problem with either the main board, the lcd screen or a connection between the two. If you need help with that one, the place that you can have it serviced is: www.camerasandparts.com All they deal with are the service for the Canon Powershot cameras. Not expensive at all and the work through them is superb. Hopefully that helps get you in the right direction with it. Good luck
tip
How to improve picture quality of Digital Camera
Slow down the shutter speed of your digital camera. Whenever you must take a photo in a low light environment decrease your shutter speed. It is virtually impossible to take a blurry digital photo with a an extremely slow shutter speed. Even if your digital camera has an automatic or semi-automatic mode, slowing down the shutter speed will still produce a better digital photo. <br /> Wait until your digital camera is completely focused. Most digital cameras will notify you that they are focus ready by a blinking light, on screen indicator or a noise. Confirm that your digital camera has locked onto your desired target before pressing the shutter release button. Some digital cameras may have trouble focusing on subjects easily. If this happens use an auto focus mode to produce a better digital photo. <br /> Prevent your digital camera from shaking. Shaky hands or sudden movement will definitely produce a blurry digital photo. When holding your digital camera, make sure the viewfinder is firmly pressed against your face before snapping a digital photo. If you do not have image stabilization on your digital camera, then think about investing in a tripod. This will allow you to steady your digital camera for the perfect shot. <br /> Make sure the digital image is definitely a blurry one and not just a soft image. On many occasions soft images are mistaken for blurry ones. Soft images occur often with digital cameras. When printing these images, the softness rarely shows through. You will be able to easily edit these photos by sharpening the details for a better printing experience. <br /> Take your time. Instead of rushing to take a digital photo, set aside enough time to shoot your image. Hurrying up will not produce an excellent digital photo. You don't need to be overwhelmingly slow when taking the photo, but try your best not to take a hasty one.
on Dec 31, 2010 • Cameras
Hi I find my shutter speed is slow.. I take a picture of a slow moving object and by the time the photo is taken, the object has moved out of frame
You need to press the shutter button half-way and allow the camera to lock in the focus (it will beep) and then, when the moment is right, press the rest of the way....result....instant picture...no delay.
When useing under water the shutter was so slow, when frameing a shot of a fish. By the time the shutter operated the fish was gone. can we lock the focus so it takes the picture quicker.
By pressing the shutter button half-way until the camera "beeps", you lock in the focus. However, underwater in a waterproof housing, I'm not sure you can hear the beep.
4answers
How do I change the shutter speed?
This is "shutter lag," the delay between pressing the shutter release button and the camera actually taking a picture. This is a common situation with many compact cameras. The camera has to focus on the subject, meter the exposure, and switch the circuitry from displaying on the screen to recording the image and saving it in memory. More sophisticated (and expensive) DSLRs eliminate this shutter lag by having more dedicated hardware for this.
With a compact camera, you can reduce the shutter lag by anticipating the shot. Press the shutter release button halfway to focus and meter the exposure. Continue to hold the shutter release button halfway until the right time, then press it the rest of the way.
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Sony DSC H-5 Camera slow response time
There is a diaphram between the shutter button and the shutter that does the focus. Pushing the button half way down pre-focuses and then the picture is instantanious. If the diaphram is broken it take a while before the shutter takes the picture. One of the AA batteries may be defective so try another set and see if that is better. There is also a slight possibility that the secondary battery (hidden within the camera) has gone bad.
The camera is slow to take a pic when i push the button! Is there a way to make the camera take a pic immediately when i push the button?
I assume you're using a point&shoot camera.
You can get faster response by pressing the shutter button halfway to focus and meter, then press it the rest of the way when the action peaks.
One of the advantages of higher-end cameras is the shorter shutter lag.
1helpful
TROUBLESHOOTING c-750
There are a couple issues related to "slow" that I have with my C-750, and this is how I get around them.
One is the write speed to the xD card. This can prevent you from taking sequential pictures quickly, as the camera displays the current picture it is writing until it finishes. You can make the image of the current picture go away and use your viewfinder again, while the camera is writing the picture, by pressing the shutter button halfway and releasing it. Then you can see your subject in the viewfinder again!
Second is the delay between the time the shutter button is pressed and the time the shutter actually opens (when the camera actually takes the picture). This can be fixed by lining up your shot and pressing the shutter button halfway and holding it for a few seconds. This will give the camera time to adjust and lock focus, shutter speed, etc. There is a small green dot on the display below the battery indicator which will blink a few times when the button is pressed halfway, then remain on steady. When the green dot is steady, the camera is ready. Press the shutter button, and the camera should immediately take the picture.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
