20 Most Recent
Kodak EasyShare CX7530 Digital Camera Questions & Answers
Pink tint when shhoting in bright sunlight
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
Sandisk 64gb ultra
Not with this camera. The CX7530 works with MMC and SD cards, which max out at 2GB. It will not work with larger memory cards.
Lens won't open and retract.
It sound like a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
In any case it could not make it worse
My camera wont format
The CX7530 works with SD cards. It will not work with higher-capacity SDHC cards. You need to use SD cards, 2GB and smaller.
My koodak camera wont format
Set the time and date
If you want your camera to automatically deface all your photos by scrawling a string of numbers across them, press the MENU button, use up/down-arrow to select SETUP (three horizontal slider), press the OK button, use up/down-arrow to select "Date Stamp", select the desired setting, and press OK.
How do i load pictures to pc from camra with usb
Most of the digital cameras come with a software to do that. Firs and the most important thing is to make sure the drivers for you camera are loaded and your camera is recognized by the computer. The rest should be easy, just launch the photo manager program that came with your camera and the rest is easy as following the instructions. If you did not get a software package from the manufacturer you can down load it from the internet.Check Out:-
