The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
