20 Most Recent Canon PowerShot SD200 / IXUS 30 Digital Camera Questions & Answers
Does the camera accept SDHC cards (which is what you have)? if not that is the problem.
Canon PowerShot... | Answered on Jan 18, 2017
This video covers troubleshooting steps for camera memory card error.
And this webpage goes into more detail
http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html
Canon PowerShot... | Answered on Jan 09, 2015
E18 Error Fixed Canon PowerShot A520 My lense would not come out and would give me the E18 error and shut down.
I just pressed the power button on and held it down while extending the telescopic zoom lense. It made a horrible sound but the next thing I knew the lense extended out and the camera worked again!
Canon PowerShot... | Answered on Nov 07, 2014
You may download Canon software from here.
You don't really need to use ZoomBrowser. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as ZoomBrowser or Picasa.
Canon PowerShot... | Answered on Feb 28, 2013
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Canon PowerShot... | Answered on Feb 14, 2013
I highly recommend this data recovery program called asoftech data recovery.It is a comprehensive data recovery program that support deleted recovery, formatted recovery, partition recovery and Raw recovery.You can use this file recovery to get your files back easily! Here is the link
http://www.asoftech.com/data-recovery-software-download.html
Canon PowerShot... | Answered on Oct 28, 2012
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Canon PowerShot... | Answered on Mar 05, 2012
Do the cards that you are using say SDHC? If so your camera is probably not compatible with them. Try using a regular SD card (no HC) and that might solve your issue. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Canon PowerShot... | Answered on Jul 01, 2011
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Canon PowerShot... | Answered on Apr 02, 2011
The memory card may need to be formatted. You can do this by plugging the memory card into an sd usb reader (separate purchase) and opening up that drive in your computer right click on the memory card drive and click properties and one of the options should allow you to reformat your card. This will erase any info on the card.
Canon PowerShot... | Answered on Mar 03, 2011
maybe you insert more capacity of support th memory card 16 gb only trye with 16 gb . good luck Anderson From Dominican Republic. Visit us to be uon the sky with our sunny days.
The only think I can suggest is to never buy a camera that is not waterproof. I have learned my lesson several times, but never again. Here is a link that talks about the best waterproof camera that I have used: http://hubpages.com/hub/Best-Waterproof-Digital-Camera
Canon PowerShot... | Answered on Feb 21, 2011
Did you try re-installing the software that came with your computer?
I would remove the program and re install it
Canon PowerShot... | Answered on Feb 10, 2011
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Canon PowerShot... | Answered on Dec 25, 2010
Many people are unaware that the newer SDHC format cannot be used with most older cameras. Your camera was manufactured well before the SDHC format came out. I'm sorry, but there's no way that a 4GB SDHC card will work with your camera, it just doesn't understand the new format of the card. The max size card that you can use with your camera is a standard 2GB SD card. More info may be found at this link.
Canon PowerShot... | Answered on Nov 18, 2010
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
69 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
memory card error
  • Cameras
