We have replaced cold control 2 times in 1 year. 1st worked good for the year , but new 1 wont hold steady? Temp. goes from 27 deg to 50 deg. It has been 3 weeks since control was replaced . Both times the frige side froze everything, busted the water filter cup, water every where inside(did it in the night). The freezer side seems to be good. What could it be now?
SOURCE: freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Hi friend, thank you for your inquiry!
I understand that you are having difficulty with the temperature settings on your Frigidaire refrigerator. Depending on your refrigerator style on a top mount there should be a cold control on the inside of the fresh food side that would be used to adjust your temperature. On a side by side or French door bottom mount the temperature control is located on the front control panel. Typically, as a "+" or "-" symbol to adjust the temperature. If any adjustments are made to the temperature, please allow 24 hours for the temperature to set properly. I hope this information has been helpful. -Matt
