For some reason the printer cannot read the electronic strip correctly on the cartridge. Make sure the protective tape has been removed prior to install. Also, make sure the cartridge has been carefully installed properly so that the electronic strip meets the backing close enough to read. If there is any ink left on this area, that can cause interference too. clean with alcohol and clear debris. After you reset everything, unplug power cord and leave separate for a couple minutes. reattach and try again. good luck!
