When you're embroidering, ALWAYS have the tension set on "E." Unfortunately with a Singer, you will always have bobbin thread pulling thru to the top-I found this out from a technician a few years ago who also serviced Vikings and Husqvarna's. He went through a lot to show and explain it to me, but suffice it to say that with a Singer you need to use the same thread in the bobbin as on top when you're embroidering-it's simply a flaw with their machines.
The bird's nest could be a number of problems, but first we need to be sure you're setting your tension set on "E". If you are, leave me a comment back and we'll go through some specific steps to take about the bobbin. Otherwise, correct you're tension setting and see if that corrects the bird's nest problem. If not, again, leave me another comment back and leave me any details you can as to the type of material your embroidering on, the thread you're using, etc. It may seem like a pain, but you'd be surprised how fussy the littlest thing can be. I check in daily, so I'll get back to you within 24 hours. I've used my CE100 for 4 years and have mastered it quite well, so I feel confident that I'll be able to help you.
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
