Dehumidifiers Logo
Posted on Aug 12, 2008
Emerson quiet kool dehumidifier 40 frost sentry plus
We need a new water container for our emerson quiet kool dehumidifier.
how do I go about getting one?
ELAINE BARIL
12 VALLEY FORGE DRIVE
SHERWSBURY, MA 01545
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2619
Points
My emerson dehumidifer Hd14070 has to containers only one works
  • Anonymous Dec 06, 2008
    Where is my answer
Dehumidifier defroster function not working
dehumidifiers remove water from the air. They do not defrost anything.
If you have frost on the unit coils, it may be because the temp is too low (<40°F) or the unit is defective. unplug it till it melts
I just have had my new dehumidifier running since Friday and when started the humidity said 60,went down and checked it today and it still says 60,I have it set for 40,is this unusual after two days?
If your dehumidifier is working it will be extracting water from the atmosphere, into a container that will or should need emptying fairly regularly.
If it is working ok it isn't necessarily going to significantly reduce the humidity in the room as most rooms are connected to the outside world in a number of ways...
I have an Emerson Quiet Kool dehumidifier that is probably 20 years old. When it is running, you can hear the system cycling on and off every 2-3 seconds. The fan always runs. What could cause this?
The temperature sensor can be broken or because it is an old unit is the freon gas can be escaped by an internal leak in the compressor circuit and thus no longer works, there is a part to be internally freezing when the compressor is running. dismantel to look also if thereis somewhere in the circuit a solenoid-valve to find that will not get dc function by electronica.
1helpful
2answers
What can I do to prevent my Dehumidifier from building up a heavy coating of frost over all the condensing tubes. The dehumidifier is currently located in the basement.
The frost is requried for the unit to do it's work. The unit should routinely turn off and the ice should melt. without this process no water would be removed from the air....
4helpful
I have a dehumidifier (Emerson I believe - sorry don't have the model # right now) in a very cool basement (55-60 degeres). When I turn it on the coil quickly frosts up as expected and a while later the...
Dehumdifiers work by cooling a coil below the dew point temperature of the ambient air. When this happens frost or water will form on the coil. Most room dehumidifiers work with the room temperature above 65 deg F. It works well when the temperature of the room is 65 deg F or higher. But when the temp is below 65, it won't work because the coil does not reach the dew point.
There are cold temperature dehumidifiers that are designed to work in colder environments such as basements. They can work in a environment as cold as 40 deg F. Check your owners manual to see what type of humidifier you have to see what is the minimum operating temperature for you unit. Hope this helps you.
2helpful
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
2answers
Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Top Fedders Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
