20 Most Recent
DeLonghi DDE50E Dehumidifier Questions & Answers
Really thick ice on back of dehumidifier
It is now frozen because the humidistat, which controls the on/off cycle, is starting to age and forgetting to turn off the dehumidifier. Try removing the humidistat and, using compressed air, blow it out thoroughly of any dust. Then spray the rotary control area, including electrical parts, with WD-40. Then, blow dry again with the compressor and try again.
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course!
this is not ur solution
try draining all the water to the sewerage
if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump
then turn on the Dehumidifier
every time it frosts turn it off untill it defrosts
or u can heat up the basement with a bellower and the Dehumidifier
wont frost
My delonghi dem 10 dehumidifier is working and collecting water but but the pause is continuously flashing why is this
The flashing pause light on your DeLonghi dehumidifier indicates that the unit is in a defrost cycle. During this time, the compressor shuts off and the fan continues to run in order to thaw any ice that may have formed on the coils. This process typically lasts for 10-15 minutes before the unit resumes normal operation.
If the pause light continues to flash even after the defrost cycle is complete, it may indicate a problem with the unit's sensor or control board. In this case, it is recommended to consult the user manual or contact a professional for assistance with troubleshooting and repairs.
2/26/2023 2:11:51 PM •
DeLonghi...
Answered
on Feb 26, 2023
DELONGHI DH300P E3
The E3 Code, indicates that the air intake filter needs to be removed and cleaned. Be sure the unit is OFF and unplugged before removing the filter. Filter cleaning should be performed at least once every two weeks, as part of Routine Maintenance.
6/6/2020 6:44:27 PM •
DeLonghi...
Answered
on Jun 06, 2020
