Http://tricks-collections.com/download-link-resetter-epson-t11-t30-t33-t50-t60/
At the link above, you will find the Epson T60 Reset program. Download it and run it.
If this doesn't work for you, here is a more technically involved reset method:
http://tricks-collections.com/reset-epson-t50-t60-without-error-21000068/
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Download the Resetter for your Epson T60 here:http://www.mediafire.com/download.php?nz... Extract the files to your hard drive. Open the AdjProg.exe, press Accept, and then proceed with the reset.
If you are using Windows Vista or 7, follow the procedure here:http://tricks-collections.com/how-to-run... You must run the program in compatibility mode.
Did you extract the files from the downloaded .rar file? You must use WinRAR, available here:http://www.win-rar.com/download.html
This download has been tested, so I know it works on Windows 7.
Want do you mean reset? Reset default setting?
You need go to printer icon, right click mouse, printing preferences and there should somewhere there the restore default setting.
Please tell me what the exact problem it?
Or set up again the printer by adding new printer with same name and set it as default printer. Check if the solves your problem and let me know if you need more help
Hi you need a software to reset the ink pad error which ca be purchased and can be refund it not working good. It is USD5 only
http://www.youtube.com/watch?v=3ao_PZVsO...
please try also this link http://www.epson.com/cgi-bin/Store/suppo...
Ok try this linkhttp://inkjetprinterhelp.us/epsonSSC.htm...
Just install it and select your printer
Just try to install it and choose your printer. What is important is it is detecting your printer and we need to reset the ink pad error message. Just follow the procedure on how to reset
Use this link, download and install this in you computer. there is a guide on how to reset the ink pad setting. The 1st line choose your printer and the other ignore it. Look for Protection counter (on the SCC utility icon)
Hi here try this for T60http://www.sulit.com.ph/index.php/classi...
Also this for T60 http://tricks-collections.com/download-l...
Also, this http://blog.indodx.com/archives/download...
Does it helps you. I give all now for T60 epson
I give thre new link for T60 epson. view all the comments I posted pls.
click on view more comments
Ok give me your email address I will send immediatelt the 3 links I posted.
As I told you, you need a ink pad resetter software to remove this error http://blog.indodx.com/archives/download...
http://tricks-collections.com/download-l....
I posted these two softwares.
The printer's ink pads are at the end of their service life. Please contact Epson support.
this is the problem and blink red lights on ink button and other button
to mark epson t60 wasnot there
there are no model like t60
this link no model t60 some other models only
this epson link does not shoe t60 model
this epson link does not shoe t60 printer
hello sir,
the link your given me does not shoe t60 model
the epson link that you given to me please check by your self. there are no t60 model
there are no model to select epson t60
my epson t60 printer has display this massage'The printer's ink pads are at the end of their service life. Please contact Epson support.''please advice to me how to sole this problem
532 478 152 teamviver id
pasward is 4142 can you please do for me
i down lord this but cannot run
