First setup the port forwarding and then choose the firewall section. After that you will get the PS3 or Xbox360. To set up the static routes, in to the Network, in to that go to LAN, after LAN go to Client List, then select ADD. Enter the MAC address of the PS3/Xbox360 and the reserved IP address. Also you need to on the UPnP form the settings. Go to the advanced settings of the UPnP then tick all the three boxes present. check what happens Then go to Network, NAT. Activate NAT. Select SUA. Enable SIP also.
Zyxel routers don't support Nat 2 confirgurations for the PS3 software. You can fix some issues by powrforwarding the speciffic ports that the PSN uses. To do so follow this ismple guide:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/PlayStation_Network.htm
It may vary from game to game so you should choose what speciffic product are you trying to use here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
