Olympus VN3100 Handheld Digital Voice Recorder Logo
Anonymous Posted on Mar 05, 2011
Hi, My husband either deleted or recorded over a file on his digital voice recorder. How can we retrieve the recording? Thx!
Anonymous
Level 2:
  • Expert 157 Answers
  • Posted on Mar 05, 2011
Anonymous
Expert
Level 2:
Answers
157
Questions
0
Helped
55109
Points
442
  • Anonymous Mar 07, 2011
    P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
8helpful
4answers
How to recover deleted files from olympus digital voice recorder VN6200PC
You can recover deleted files with asoftech data recovery software. get the software from link below
Voice Recorder Data Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
Inadvertently deleted all files from voice recorder. Must recover. Please help!
Try to retrieve deleted files with the undelete tool after you have connected the recorder to your Windows computer.
3helpful
7answers
Can you recover deleted files from the Olympus Recorder VN-4100PC? also, one of my files is unable to play. any way of recovering it?
YES, it is definitely possible to recover such kind of files deleted from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. I hope this will help. Best regards!
3answers
I deleted seven voice files off my Olympus DS-2300 and need them back! Can they be restored or retrieved?
Yes, those voice recordings can be recovered provided not overwritten(if you keep taken more records, then possible). The best way is to try some audio recovery software. Here are some for your option. Both programs can also recover videos and photos.
Photo Audio Video Recovery Software (for Windows)
Mac Photo Audio Video Recovery Software (for Mac OS X)
Note: Before your audios are recovered, do not attempt to save more files.
9helpful
4answers
Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
2answers
Retrieval of deleted voice recorded file
maybe, there are programs that retrieve deleted files, but sadly you need to buy them.
this only works if you havn't added any new voice recording (or a lot of voice recordings) or if you havn't reformatted your player.
How do I get back deleted voice files from my Olympus VN-3100PC digital recorder?
Unfortunately because the device has flash memory the voice files once deleted are unable to be retrieved. You may try to google search for companies that specialize in flash memory recovery but it is a very expensive process.
2helpful
6answers
Olympus ds-30 deleted file recovery
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
2answers
on your computer, you will need some sort of media recovery software. also go to options under the tools menu and uncheck delete after transfer to turn off deletion. this is usually best since you can delete the files through the recorder by the erase button
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
