Garden Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken tines on honda tiller fr650 model need part numbers for left and right tines, or location near or in Concord NC I can purchase them.
Anonymous
Level 2:
  • Expert 130 Answers
  • Posted on Feb 24, 2011
Anonymous
Expert
Level 2:
Answers
130
Questions
0
Helped
73191
Points
397
I will supply you with the part no. I have:
06722-777-000 TINE KIT, ROTARY
72100-777-013 TINE ASSY., R. (OUTER) Use up to Frame SN 1021912.
72100-777-023 TINE ASSY., R. (OUTER) Use from Frame SN 1021913.
72150-777-003 TINE ASSY., R. INSIDE Use up to Frame SN 1021912.
72150-777-013 TINE ASSY., R. INSIDE Use from Frame SN 1021913.
72200-777-013 TINE ASSY., L. (OUTER) Use up to Frame SN 1021912.
72200-777-023 TINE ASSY., L. (OUTER) Use from Frame SN 1021913.
72250-777-003 TINE ASSY., L. INSIDE Use up to Frame SN 1021912.
72250-777-013 TINE ASSY., L. INSIDE Use from Frame SN 1021913.
Hope this helps. Make sure you verify the frame serial number. The tine assy. include the hubs and mounting hardware.
Troy bilt horse tiller tines turn, right wheel turns, but left wheel doesn't turn
Purchased hahn tiller 5hp briggs stratton with broken tines and bearing and seal leaks. where can i get parts
Parts for the engine can be purchased from briggs and stratton
The bearings and seal can be purchased from Napa. Dimensions are required for the bearing inner and outer diameters. (Caliper time)
The tines.... I don't know. My experience on the tines is you either find an old Hahn Eclipse Tiller for parts or you find a good craftsman that can make one. I had to make a LH tine using the broken parts, some forge hardened bar stock and a welder. The tine manufacture took much longer than expected...!
Kelly
Apr 23, 2011 • Garden
TROYBILT BRONCO REAR TINE TILLER Model#21A643B066...HOW DO I CHANGE MY ENGINE OIL?...WHERE IS THE DRAIN PLUG LOCATED?
The drain plug is generally located on either side of the engine near where the block bolts to the frame of the tiller. It can be a square headed plug or an allen socket head plug.
Where is the model number on my troybilt rear tine tiller?
If it's as old as mine (circa 1976), it's stamped on the casting right below the T-handle that allows the handle bars to pivot (also the gear case fill cap)
4helpful
2answers
Replace belts on Montgomery Ward rear tine rototiller Model number GIL39012B need diagram
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
2helpful
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 • Mtd Garden
5helpful
2answers
Need manual....for 917293401. took it apart and can not put back together
here ya go! go to this page and there is 7 blue links to choose handles,frame,transmissin,ect..each has pictures and part numbers
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=917.293401
  • CRAFTSMAN
  • REAR TINE TILLER
  • Model# 917293401
Browse Subcomponents To make your search easier, we have grouped this model's parts into subcomponents. Please choose a category below to view the related parts and diagrams.
r3_placement('category_page.bottom_modelsearch'); r3_placement('category_page.bottom_modelsearch');
1helpful
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
3answers
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Top Garden Experts
Jay Finke
Jay Finke
john h
