lights come on in the car, when I turn over the key the car won't turn over. no clicking sound but I do hear the fuel pump pumping.just don't do nothing.lights come on in the car, when I turn over the key the car won't turn over. no clicking sound but I do hear the fuel pump pumping.just don't do nothing.
You can't post conmments that contain an email address.
Obviously, you can jump the relay but it is dangerous on an extended basis. You'd have pressure in the lines when you don't want it there. Replace the relay if it is defective.
If you have other issues, you can check the pump back to the tank by going on the business end of the relay and looking for resistance at the pump to ground. If it is open, the pump or the harness is bad...GMs have harness issues...not Fords.
you can bypass relay but its only a tempory fix if you r stuck by feeding wire from positive side of pump direct to ignition so that pump switches on when you switch ignition on still get fuel pressure
In most cases, the primary symptom is a check engine light.And you know what this means right? It’s a sign the ECU is holding on to some trouble codes. In order to read the code, you’ll need to hook up an OBD2 scan tool. If you find a P0230 or P0231 OBD2 Diagnostic Trouble Code (DTC), this means a malfunction in the primary circuit of the fuel pump.
First, the power relay turns on engine computer. Then the engine computer turns on the fuel pump relay which in turn, turns on the fuel pmp for 5 seconds, unless the engine is running. If you have a new pump, check for spark right after it dies next time.
Check for fuel pressure on the fuel rail while turning the key to start,if there is fuel pressure(enough)then the injectors are not pulsing(allowing fuel into the intake).The pick up coil in the distributor,will be the problem,unless it is distribuless ignition,then the cam sensor would be at fault.
It shouldn't have anything to do with it. The fuel pump relay doesn't activate without the key being turned to the on or start positions so i can't be draining your battery.
My 96 Probe GT had the same thing. I changed the fuel pump and thought i fixed the problem. Not so. I then changed the crankshaft position senser and that was my problem.
Section 18-01: Wiring and Circuit Protection
1996 Probe Workshop Manual
REMOVAL AND INSTALLATION
Relays
The following illustrations show the locations of the various relays on the vehicle.
The Location of the Starter Relay, Main Relay, Circuit (Fuel Pump) Relay, Turn Signal Lamp Relay, Horn Relay, Daytime Running Lamp (DRL) Relay (Canada Only), A/C Relay, Headlamp Relay, and Fog Lamp Relay
