Mitsubishi medallion ws55819 rear projection tv will not power on. power light comes on for about 3sec, and then goes out. i can hear the relay on the circuit board picking on and off.
Check for bad solder on
convergence module. May have bad stk's. Do not neglect looking
for bad solder on dsignal and defl boards. Mitsubishi is very prone
to bad solder.
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
when power light comes on and then goes off: On the front of the set press and hold both Menu and Input (or device) buttons both for at least 5 seconds and then release both.
The power light should blink a two digit error code--like--2 blinks, a pause, 2 blinks..........it will repeat the error code several times.
Let me know what you find and I will tell you what the error may mean.
If this helped you rate this solution as I do this here for free.
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
check the horizontal transistor thats close to the lines transformer and see if its bad if not then resolder all open circuits and broken lines
hope this helps
rate me
