Usually that indicates a fatal issue. But try The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
SOURCE: D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
SOURCE: I cannot connect my xbox 360 to my tp link router(tl-wr6145)
Had this problem my self, try lowering the firewall on your router and make sure the network allows media sharing.
