That error, 6A00, says that the cleaning station is either stuck or broken. If the printhead is not stuck on the right, pull it out to the center and look inside with a light and see if paper scraps or something is stopping it. There is also a spring loaded squeegee that could be stuck on the rubber cups and needs to be gently pushed to the rear. If The squeegee is stuck you need to use a wet Q-tip and clean the tracks it rides on and it shouldn't stick again. If these things don't help you will need a shop to replace the purge unit. about $20.00 plus labor charges. It is too complex to replace at home.
