LG GSA 4163B DVD±RW Dual Layer Burner Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In my dvd rw drive, am able to write cd but in case of writing dvd some error i got burning process failed, some word like firmware was displayed , and the drive was able to read any dvd , only wen trying to write a dvd , it is dying. please give some idea solve this problem.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 283 Answers
  • Posted on Jan 09, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
283
Questions
Helped
42469
Points
794
Sound like your lazer is weak to burn ok to read time to replace if burning is essental
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
Dvd takes forever to burn on my dvd drive and I use nero as the burn software either the burn process fails or it take around 10 hours to burn a dvd at 16x
I would recommend trying a firmware update on the drive. What type of computer do you have? For example, HP has specific updates for drives at http://www.hp.com Otherwise, go to samsung.com and go to drives/downloads and search for what is called a "firmware driver" (firmware is software on the drive that will help it to either work better, or confirm you have a defective DVD drive.)
I had Sony dvd rw AW-G170A. It can read cds and dvds sucessfully. When i burn cd it works fine and burnt successfully. But when i burnt dvd it shows following error.power calibration error writing short...
you might want to try and update the firmware on the DVD burner, find out with the vendor if there is a fw version and how to do it, if not I would suggest hiring a professional.
2answers
1helpful
Sony DVD RW DW-31A stopped writing and not recognising CD in tray
are u copying the disc on the fly i mean directly from dvd rom to dvd rw it sometimes generate this error when reading drive stops giving data due to some error and suddenly bcoz of that the writing drive leavve the session un closed and give an error the solution is first copy ur disc on the hard drive and then copy it on another disc on the fly copying is not safe otherwise also try this
pls try to clean the lens of the drive as follows
due to dusty environment and excessive use lens gets dusty and then have problems in reading or writing dvd 's and cd's
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens or cotton bud good quality see if it works , other wise ur DVD drive lens got weak from use now adays service centers are getting tons of them everyday for replacements
u can try that software thing as well but i dont think it will solve ur problem
pls do rate me FIXYA if i fixed what u wanted
Cannot write to 16x dvd discs
Dunno. Do you have the latest firmware?
2f8 released August 24, 2008 is the latest version
=> http://www.findmysoft.com/drivers/Nec-ND-2510A-2f8-firmware-driver.html
Cant write DVDs with my DVD+RW RW8165 Drive
your drive may not be compatible with -rw disks. Try using +rw. They are totally different.
also i am having a similar issue with vista with burning dvds. I have to set it on 4x or it fails around 90 % up to 99%. Lower your max burn speed.
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
2answers
How do I find out what kind of driver I have
install nero latest version so that u can burn dvd easily use nero 7
4helpful
4answers
Dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to [email protected]
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
