20 Most Recent Samsung SH-S182 DVD±RW Dual Layer Burner Questions & Answers
0answers
What cable do I need to hook up a Samsung dvd writer sh-s182 to my Akai dps16 with scsi?
I suppose you would need a SCSI cable with the correct number of pins that match your scsi ports. Some have 50 pins some have 80 pins and some have less than 50 pins. Count your pins and go from there. Have you ever done this procedure before? Did it work?
7/4/2014 2:56:04 PM • Samsung SH-S182... • Answered on Jul 04, 2014
Driver download
What is the problem?
7/4/2014 5:35:44 AM • Samsung SH-S182... • Answered on Jul 04, 2014
I'm currently using Windows XP,
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you
8/18/2011 8:03:21 PM • Samsung SH-S182... • Answered on Aug 18, 2011
Installed Samsung SH-182 SH-S182 DVD
Which OS Service Pak is XP using? Have you tried to update the drivers? ' System ' Hardware ' Device Mgr
Can you test the burner on a 2nd PC? My older PC's dont see the DVD-RW but the burning software does.
2/22/2011 1:05:26 AM • Samsung SH-S182... • Answered on Feb 22, 2011
3answers
Samsung make TSSTcorp CD/DVDW SH-S182F
on creation or compilation of any cd/dvd regardless of disk format or capacity. the finalizing of a disk. will write a TOC ( table Of Contents ) this will inform the drive reading the disk. whats on it. even if a cd or dvd writes 1 track of music. if thats all you put on the disk, and finalise it. that will be the finished capacity. if you use rw disks. you must format the disk before re-using it.
this will completely erase all previous data on it.
If as stated you are using Nero. there are setting options, to create a multi-session cd/dvd whereby you can add additional files at a later date. however this disk will not be readable, by any other computer-cd/dvd player. until the disk has been finalised, and produced the Table-Of-Contents. ( Index )
Mike @ Compurepair.
1/24/2011 7:55:03 PM • Samsung SH-S182... • Answered on Jan 24, 2011
My Samsung SH-S182m dvdrw will
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area hope this helps
1/11/2011 8:48:33 AM • Samsung SH-S182... • Answered on Jan 11, 2011
I require the driver for Samsung SH-S182
You can find you driver here :
http://www.opendrivers.com/driver/240991/samsung-sh-s182m-dvd-writer-firmware-sb06-windows-98se-me-2000-xp-free-download.html
1/10/2011 8:46:07 AM • Samsung SH-S182... • Answered on Jan 10, 2011
Computer does not see dvd rom. it used to work but
your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
11/19/2010 5:09:08 AM • Samsung SH-S182... • Answered on Nov 19, 2010
Dvd takes forever to burn on my dvd drive and I
I would recommend trying a firmware update on the drive. What type of computer do you have? For example, HP has specific updates for drives at http://www.hp.com Otherwise, go to samsung.com and go to drives/downloads and search for what is called a "firmware driver" (firmware is software on the drive that will help it to either work better, or confirm you have a defective DVD drive.)
11/6/2010 3:11:25 AM • Samsung SH-S182... • Answered on Nov 06, 2010
System does not recognize the
at the rear of the drive Then you will find The Three pairs of pine
(From left to right)
SC, SL, Masters
change jumper to master.
8/24/2010 8:45:45 PM • Samsung SH-S182... • Answered on Aug 24, 2010
WHERE CAN I GET FREE DOWNLOAD
dont need any drivers to install drive to work
2/5/2010 8:29:49 PM • Samsung SH-S182... • Answered on Feb 05, 2010
2answers
My cd/dvd rom is not working in my compaq laptop pls help me
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
12/30/2009 2:36:32 AM • Samsung SH-S182... • Answered on Dec 30, 2009
The system recognises the device to be there but
I think their is some eye problem with your drive.
Because of that problem your drive is unable to read the disc.
you have to change your drive.
12/29/2009 11:46:51 AM • Samsung SH-S182... • Answered on Dec 29, 2009
Hello
First look and see the write speed of the drive. 1x to 4x is slow but recommended by all programs and this is initially the default settings for most programs. You must goto the settings of your dvd burning program and set the burn rate to 16x or higher.
9/28/2009 5:02:28 AM • Samsung SH-S182... • Answered on Sep 28, 2009
2answers
My cd/dvd drive is working properlly with cd but
Hello
I had the same problem. All i did was to buy lazer head cleaner disc, which you put into your rom and run the cleaning test. Mine worked fine after i did this. It is very cheap and you can use it repeatedly. You can buy it at any music store. Please rate this.
Best regards
9/26/2009 11:58:17 AM • Samsung SH-S182... • Answered on Sep 26, 2009
Unlock dvd
Info here
http://www.doom9.org/index.html?/rpc1.htm
8/5/2009 10:40:45 AM • Samsung SH-S182... • Answered on Aug 05, 2009
I/O Magic drive is really Toshiba SH-S182 - I need jumper help
The jumper settings are located in the manual. You can download it here (it takes a few minutes to download). I have tested it and it does work and has the jumper settings for you.
I would be most grateful if you would rate my answer for me. Thank you.
8/1/2009 11:30:15 PM • Samsung SH-S182... • Answered on Aug 01, 2009
DOES SH-S182 DVD WRITER SUPPORT DVD-R FORMAT DISC?
Yes
Thanks, Frank
@Tech
3868607368
http://www.attechcomputers.co.cc
6/21/2009 3:11:23 AM • Samsung SH-S182... • Answered on Jun 21, 2009
Samsung SH-S182 DVD±RW Dual Layer Burner Logo
Popular Tags
40 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SH Samsung
  • SH Samsung
Most Popular Question
39 m currently using windows xp
  • Computers & Internet
