Toshiba 65H83 65" Rear Projection HDTV-Ready Television Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just recently purchased a Toshiba 65H83 65-Inch HD-Ready Rear-Projection TV and need a remote control for easier access to all the features
Anonymous
Level 3:
  • Toshiba Master 5,138 Answers
  • Posted on Jan 09, 2011
Anonymous
Toshiba Master
Level 3:
Answers
5138
Questions
5
Helped
1004567
Points
13534
Mats Electronics 1-800-628-1118
Encompass Parts 1-800-638-3328
I recently got a 51h83 toshiba tv. When i try to hook up my xbox 360 with the hd component cables in the back i get sound but no video. Please help.
WITH THE TOSHIBA 51H83TOSHIBA TV YOU CANT HOOK UP HD CABLES TO THAT SPECIFIC TV FROM YOUR XBOX 360 BECAUSE THE DEVICE ISNT EQUIPPED WITH THAT CAPABILITY
1helpful
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
What's your problem?free owners manul Toshiba 57H83 57-Inch HDTV-Ready TheaterWide Projection TV
Please send me an email to [email protected] and I will send you the manual. Please put " toshiba 72hm195 manual" as the subject
Free owners manul Toshiba 57H83 57-Inch HDTV-Ready TheaterWide Projection TV
Please send me an email to [email protected] Put "toshiba 57h83 manual" as the subject and I will send you the manual right away. Lawrence Brown
1helpful
Does this tv need to have a digital tuner attached to it? or is it ready to use?
You need a HD cable box or go Satellite. That is a monitor set with NO tuner. FYI, the older sets that say HD Ready means No tuner. Salesman jumped all over that one when it came out. They would say Yep! it's HD ready and then jump into all the features to side track the customer, it was terrible.
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Won't display tv and there is a black box during dvd play
It sounds like you have the closed-captioning set to "text" mode. When set this way, if captioning is present the set clears the area where the text goes. You don't see the box on channels or programs where captioning isn't being used. On most TV remotes a single button controls captions, so it's easy to get into text mode without knowing it.
Cinemavision tv
Unfortunately, most of these projection TV's require a remote. You CAN purchase an aftermarket remote. I would look for one that has all the features you need, PIP, screen format etc.... I have found that the Sony RM-VL600 works real well with my Mitsubishi TV... kids thrashed the remotes more than once...
This particular unit has system control PROGRAMABLE buttons on the bottom row. I've been able to program them for formatting the screen, setting audio and video... Solved my issue of needing a factory remote.
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Surround Sound Installation
The Hitachi 50UX57B is a 50 inch standard projection TV with a standard screen. It is not HD ready. If you need it, I think I can download the owner's manual (in PDF format) from Hitachi and foward it to you.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
