SOURCE: No Sounds when connect XBOX 360 to HD port
you need to run the white & the red to the aud. input
SOURCE: Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
SOURCE: Aquos screen blacks out with xbox 360 using Component Cables
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
SOURCE: Large red bar lower half of tv sharp aquos 52" 2.5 yrs old
some parts inside your tv is damage or short circuited. too expensive to fix or replace
SOURCE: how do i hook up
You have a few options actually. depending on which 360 you have you have at least 3 ways to connect; 4 if you have CDMI cable output on Elite 360. you only need to pick one though. easiest is the plug with one yellow and a red and white. the yellow is the video and the red and white are the left and right audio. You can use the red green blue plugs choice if your tv has that input. in that case the red green blue are the video and you use the other paired red white for audio. You can use the S video connection (the round one that looks like a mouse plug) for video. You can use the HDMI (flat, looks like giant USB slot) for really high quality video. So, basically just use whatever cable you happen to have. If you still have questions, please ask as we will definitely get you hooked up for sure:) farmerbear at FixYa
