Expert
- Posted on Jan 02, 2011
Re: I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET....
Follow these steps to change print settings, and then print in Mac OS X 10.6.
Step one: Select your product
In the program from which you want to print, click File , and then click Print .
Figure 11: Click File, and then click Print
Select your product from the Printer: drop-down list.
Step two: Change print settings
Type the number of copies to print in the Copies text box.
If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
Select the size and type of paper loaded in the product from the Paper Size drop-down list.
Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
After the Orientation section, click the drop-down, and then select Paper Type/Quality .
NOTE:
This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down.
Figure 12: Select Paper Type/Quality
Adjust the Paper Type setting to match the paper loaded in the product.
Adjust the Quality setting to change the print quality of the printed page.
Select Print Borderless to print photos without a white border.
To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menI NEED TO PRINT DOUBLE-SIDED ON AN hp3150 - c02458422.jpgre 13: Color Options menu
1 - Paper Type/Quality menu options
2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job
After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
