Depending upon your make and model of oven when you first turn the oven on to heat a light may come on that says 'preheat'. When the oven is heated to the temperature that you set it for the light will go off and some models sound a tone or beep as well. If your model does not show you in any way when it is preheated ( such may be the case in an older oven)you can purchase an oven thermometer for that purpose. If you will send the information regarding the make and model of your oven, I can give you a more specific answer.
Thank you for using FixYa. Please rate this answer..
Hi friend, thank you for your post!
I know from your post that your Frigidaire oven is working but the preheat takes 30 minutes. This does sound like lengthy amount of time for preheat to be completed. From what you are describing it could be an issue with the panel, element, or thermostat. Since it could be anyone of these underlying issues I would recommend having a professional come out to diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts. -Matt
