20 Most Recent Maytag CWG3100A Gas Single Oven Questions & Answers
Good morning, your oven most likely has a weak igniter. That would keep the gas safety valve from opening properly. It will get close to the required amperage but valve will only flutter and not allow enough gas to ignite. Hope that helps.
Maytag CWG3100A... | Answered on Feb 11, 2018
hi there,
can you tell me the model # on your stove please?
Maytag CWG3100A... | Answered on Nov 29, 2014
You could have a weak ignitor which can cause a smell of gas, I would have it checked unless you have a way to test for amperage. Test with amp probe should read 3.2 -3.6 amps if less than 3.0 replace ignitor. I hope this helps.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Maytag CWG3100A... | Answered on Aug 10, 2014
You need to remove the door before you start dismantling the door. It is labor intensive and to hard to explain but here is a diagram that shows you the break down. Here is a video to point you in the general direction for the repair.
Maytag CWG3100A... | Answered on Aug 03, 2014
Hi Mary. I had a bad bulb in my Maytag new from the factory. I also had a hard time getting the glass lense cover off, and didn't want to be too rough with it for fear of breaking it. But it WILL come off if you turn it hard enough. I've since seen suggestions about putting warm water on it to loosen it up. And another person wrote and said using an oil filter wrench on it worked like a charm.
Good luck
No you do not have the correct board most parts retailers will not accept a return for an installed part
Maytag CWG3100A... | Answered on Jan 30, 2014
you'll need a glow starter (it works same as an pilot) or something like that, you can get to it from the back, check resistance and most likely they are bad.
Maytag CWG3100A... | Answered on Jan 23, 2014
Somethin's burning.
Get a gasfitter to check air/fuel ratio and,
well,
clean the oven...
Maytag CWG3100A... | Answered on Oct 18, 2013
Your LP provider should have all the necessary components to make it work.
Maytag CWG3100A... | Answered on Mar 06, 2013
That is usually a sign that the spark module has gone out and needs replacing. This is only if the clicking continues after all the burners are in the off position
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Maytag CWG3100A... | Answered on May 28, 2012
you have a stuck light switch, either at the door or on the control panel. either will most likely need to remove the oven at least part way. then a test of the door switch will tell you if that is bad or not.
Maytag CWG3100A... | Answered on Feb 04, 2012
it may have burned up all of the small circuit boards in this gas oven , I wouldunplug it then open it up to see what is burned and also replace the cord first ,get back to me after you open it and see what you have , only do this if you are able to work on circuits or cords replaced
Maytag CWG3100A... | Answered on Dec 26, 2011
check the igniter switch on back of stove might have gone bad. Also make sure your stove did not get unplugged by accident. no electricity no spark
Maytag CWG3100A... | Answered on Nov 22, 2011
Maytag CWG3100A Gas Single Oven Logo
185 questions posted
Top Maytag Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
hadle broke one sid oven door
  • Ovens
