The timer motor is bad, you can order a new one at reliableparts.com , using your model number. For information on how to perform your repair please reply and i will be happy to help.
Thanks, Repairman45
Testimonial: "Very helpful...now I can start investigating rather than guessing...many thanks!!"
Yes, all you need is the timer assembly, unless the dial or knob is broken. It is a little tricky to replace. You will need to remove the entire front panel that it is mounted to, in order to access it from the back. Remove the knob and dial, and then unscrew it from the back and turn it to pull it out, Reverse the steps to install the new one.
Thank you!!! I will order part today...have a great holiday!
Now washer is not taking water...UGH! Is this also "Timer related"?
could have to do with the timer most definately, once you replace it let me know how it goes.
well I received the timer today, installed relatively easily and started up the washer. Good news...I got water in the tub. Bad news: same problem as before, won't cycle through the different settings unless I do it manually...
Any ideas where to look for a solution????
Thank you,
Van
Vinton, CA
Repairman45...
Did you receive my latest note?
Sorry, i was out of town yesterday, is it possible for you to send a picture of back of the control panel?
Thanks for getting back to me...To disconnect the timer motor I removed the panel between the washer and dryer and reached up behind another panel to make the switch...is that the control panel?
Thank you...sorry to be a pain but hate to wear the same clothes all the time!
Correct, that is the control panel.
Repairman45...can you send me your email address so I can download the picture of the control panel...I do not know how to send via fixya.com
send to [email protected] ..
.thank you,
Van
Please let me know how to send photo of control panel, I need to get this washer fixed!
Thank you
You still around repairman45?
Was that the issue? Just a timer? I am having a similar problem, if I put the washer on the heavy cycle, it starts, but then starts before it passes the light soil cycle, but if I start at the low soil cycle it will go all the way through. Is this a timer motor too?
To; Repairman45
Thank you for the help re: my Maytag stackable...As suggested I looked up parts on Reliable Parts website...should I be ordering just the timer unit? Is it relatively straightforward to replace? We live out in the country a repair service out here is a challenge.
Many thanks,
Van Batchelder
Vinton, CA (Northeast CA)
