20 Most Recent Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Questions & Answers
Cloth not dry
Check for a build up of lint in the exhaust duct, an excessive build up will block air flow. Also 220VAC electric dryers use different legs of the electrical supply. (two 110VAC legs tied via a common neutral make 220 VAC) One 110VAC leg runs the motor and controls while the other supplies power to the heater. It is possible that one side of the 220VAC has a blown fuse and is not supplying power to the heater element. Other possibilities: Blown out heater - requires replacement There is a safety switch attached to the shaft of the motor. THis switch relys on centrifical force to close and is intened to kill the power to the heater if the motor and its attached blower stop turning. If the motor is not turning fast enough of the switch is worn then it is possible that power to the heater circuit is not being completed. It doesn't take must of a speed reduction to cause a problem. Lint build up on the drum bearings can cause enough drag to slow the drum slightly. Combined with a worn/dirty switch and the switch fails to operate. Finally there is a blower attached to the motor shaft. The blower is made of plastic and somtimes the blower comes loose on the shaft. Usually you hear a rattling sound or sounds after the dryer drum stops as the loose spinning blower spins to a stop. ( A tight blower stops with the dryer drum) A loose blower doesn't move enough air and causes your dryer to run longer.you can find about uniforms: https://www.mysocceruniform.com/customsocceruniforms.html
3/13/2014 10:45:43 AM • Maytag Neptune... • Answered on Mar 13, 2014
Silly question - where do you add the detergent?
Often you will find the detergent dispenser very close to the dispenser for the softener. Mine is a separate container within the same "pullout" drawer that holds fabric softener. If you still are not sure, then find the model number of your washer and google it with the term, "user manual". Most are available online as a PDF
11/22/2013 6:21:09 PM • Maytag Neptune... • Answered on Nov 22, 2013
Where does the detergent go?
lift up the cap on the middle of the bit that is in the middle under the lid
11/22/2013 6:05:06 PM • Maytag Neptune... • Answered on Nov 22, 2013
Maytag washer does not spin
What is the complete model number of your unit?
12/8/2012 12:44:16 AM • Maytag Neptune... • Answered on Dec 08, 2012
2answers
My washer broke and left a lot of water in our
Try extra detergent in a load and oxyclean. It might take 2 wash cycles. Good luck!
11/12/2012 1:45:19 AM • Maytag Neptune... • Answered on Nov 12, 2012
I have a neptune stackable w/d The light in the
Your best bet now is to call for service cause it can be multible problems.
9/25/2011 8:14:56 PM • Maytag Neptune... • Answered on Sep 25, 2011
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
Popular Tags
80 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
neptune mle2000ayw
  • Washing Machines
