Nice job Dan! Also make sure that the cigarette lighter adapter is fuse protected! If you need your cigarette lighter to run a GPS, laptop, etc.., simply purchase an adapter for your cigarette lighter to run 2 items! Just do NOT use the dual adapter to plug in a cigarette lighter because it will fry the adapter and possibly short out whatever else is plugged into the dual adapter! Good Luck!
"WILDCAT" IN LAURELVILLE OHIO
35 years in the cb world!!!
About your radio.......I also suggest that you upgrade to a Cobra 29! it is the most common radio and best selling radio in the world as for mobiles! Take it to a tec and get you a "swing kit" and BE SURE TO TELL HIM TO LOWER THE "DEAD KEY" AS LOW AS POSSIBLE (UNDER 2 WATTS) and to max the "MODULATION" by turning it up and NOT clipping the resistor! Then you will be LOUD AND PROUD!!!
35 YEARS OF CB FUN!!!
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
