Ithaca Posjet 1500 InkJet Printer Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I try to print an invoice in French language, some of the french special characteeers are not printed properly on this printer. Ex: 1. é is printed as ? (question mark) 2. û is printed as ? (question mark) We have corrected this problem in Dell and Lexmark printers by setting the Symbol Set as 9n ISO 8859-15 Latin 9 on printers in the following path.. Settings -> PCL Emul Menu -> Symbol Set -> 9n ISO 8859-15 Latin 9. Is there any way that I can set the above mentioned symbol set on Ithaca printers.? Please help me in this regard. This is a very critical issue we are facing.
Anonymous
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Master 1,751 Answers
  • Posted on Dec 05, 2010
Anonymous
Master
Level 3:
Director Badge:
Answers
1751
Questions
Helped
359231
Points
4943
You need to install the driver
and the windows in french laguage
Hello how to use keaboard in french please. Thanks
You will use this the same way in French as you do in English, or Spanish, or whatever language you prefer.
You simply push the keys you wish to use to spell the words, an then print the results, if you have a printer.
Hope this helps.
HELLO SEARCH USER PDF MANUAL IN FRENCH THANK YOU
You can download the pdf manual in french from its official site.
1)Go to the link http://software.canon-europe.com/
2)Under multifunctionals select PIXMA MX310
3)Select your OS and select your language as French and give submit
4)You can find the user guide in french at the last.
You can download in whichever language you need.
Hope this information is useful to you..Feel free to post your comments.
Thank you for using fixya...
BEST WISHES..
For some reason, when I print, the language appears in French I would like to change it to english
Go to this website and you should find the solution to your problem. The reason the French showed up was because the wrong .dll file was selected. There may also be a need to check to see if the correct .inf file is selected too.
http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1281987354327+28353475&threadId=1296658
hope this helps.
When I enter the print menu properties language is french.
Hi there
Not know if you got the maual.
I have put an PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Brother-MFC-215C-MFC-425CN-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Scanner is in French/ need English/ printer is in english
Press
MENU
SCAN
COPY
SCAN
That will enter Service Mode.
Right arrow to #5 and press OK
CYGNUS-1 for the MP750 and OK
Select "standard region".
Then press the power button off and on, when it comes on you should be able to select language.
More here - http://damnprinter.com/165/canon-mp750-and-mp780-cd-printing-instructions.html
Cheers!
When printing, the menu language appears in French
Sacre Bleu!
Do a factory reset on the printer (consult your manual) and see if that resolves the issue.
It prints in bad language format
It's not the printer that determines the language that is printed. It is the operating system and/or the program that is printing. Also, what you type.
In computers that run Windows operating systems it is chosen in the Control Panel. Use the Start button. Choose Control Panel then Regional and Language Options. Select your language in the pulldown menu. The entire system, including prompts, titles, etc. will now revert to that language. It will not, however, do a translation. If you have documents that were written in English they will still be English. If you want to type in English and print in French it will not happen. You must type in French to print in French...Comprenez-vous ?
A simple translator is available at http://www.reverso.net.
Old computer in office has everything in French. How do I switch it to English?
Hi try switch pc on, click "start" then "control panel" then " regional- language" (globe) select required language
Top Ithaca Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Ithaca Office Equipment and Supply Expert? Answer questions, earn points and help others
