Siemens SpeedStream Modem (4100) (SS4100) Logo
Posted on Jun 26, 2008
Security code i am trying to get a wireless network for my computer and i need the security code for frontier secure network. can you help me?
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jul 17, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
6092
Points
19
If you are using a siemens 4100 modem alone.. siemens 4100 modem has no wireless capabilty unless there is a wireless router plugged in..
if you already have a wireless router.. the SECURITY CODE shud be provided by your wireless provider
REMEMBER: SIEMENS SPEEDSTREAM is not wireless capable
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1helpful
I need the code in order to set up my e472vle 47
Are you looking for the wireless network security code?
This is a password to join the wireless network.
Connect the computer to the router. Open the setup page of the router.
Go to Wireless settings and find the wireless security password.
Read more about wireless network security code
2answers
I dont know the code forgot the code for other computers to get conecct like a ipone for the computer
Welcome to Fixya. If you forgot the code or the Network Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed to connect your iphone.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
5helpful
What does it mean by network security key
The name 'network security key' is itself self-explanatory. Every network has a security key and you will need this key to be a part of that network. Just as is the case of any other term that comes from the field of network engineering, there are a lot more details attached to this term, too. So, let us try to understand all the aspects related to network security key
An explanation as to why we need a wireless network security key is not even required. Still, if any one is skeptical about adding any complexity to their available wireless network, just think about it. Your wireless network range can be detected by any other computer with a wireless setup and that comes within the range of the network. So, without you knowing, it's very easy for any user to get connected to your wireless network and gain access to all the data that you intend to share only with those computers with which you have setup your wireless network. So, what is a wireless network security key and how is it useful in such situations?
Well, a network security key or passphrase is something like a password, which any user who wants to connect to your computer will require. But, I think that before we go into the details of figuring out, how to get network security key for wireless computer, we should take a look at the different methods of securing your wireless network
1helpful
2answers
My daughter set the router up and then moved out with the setup disc and she doesn't remember the pass code. My signal is not secure and my neighbors all use it. How can I make it secure? It always wants...
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
2answers
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
1helpful
2answers
Hi. i have been trying to secure my wireless connection for some time now. i tried doing what has been instructed but so far, im not getting the window that would enable me to do just that. would...
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
3helpful
2answers
Wireless adapter
You will need to check the wireless settings of
the router.
wep key is a password for the wireless network.
your wireless network must be secured. You will need to check the wireless security settings on your router.
Is there any computer online using the router.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
2answers
What is the WEP key
Wired Equivalent Privacy (WEP)
WEP is an older network security method that's still available to support older devices, but it's no longer recommended. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. However, WEP security is relatively easy to crack. f4008eb.jpg
How do i set up a security code for my belkinN1 wirless router?
Are you trying to secure the wireless network then you will need to access the router setup.
is there any computer connected to the router?
if not then you will need to connect the computer to the router.
once you open the router setup, you will see the option of secure the network
click Here for step by step solution
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
