Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Jun 24, 2008
Access 2007 If i have long, muliple word field names, how can i break it up into two lines? The ALT+Enter from Excel doesn't work.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 27, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1181
Points
7
Breaking a field's title on a report into two line is done in the form design screen. Data table view does not support you need.
1helpful
4answers
How to convert 2007 excel sheet into 2003 excel sheet
if you have excel 2007 you can save the file into excel 2003 compatibility
if you have excel 2003 need download compatibility pack from this page
http://www.microsoft.com/downloads/en/details.aspx?familyid=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
install it and success!
2helpful
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
1helpful
2answers
Date change
If you are using Excel 2007 ...Open Excel ... Click the Office button ... select Open ... highlight the file you wish to open ... then at the bottom of the dialog box click the downarrow next to Open and choose "Open-Read Only".
or
Before opening your old document(s), right-click the file ... select properties ... place a check mark in the box Read-only ... Select OK. Your application should open the file in Read-Only mode and will not be able to make changes or save the file.
Same as above really
I have fixed my problem. I realised that the Microsoft Access Database DSN did not include the *.accdb driver. I deleted the existing DSN and created a new one. This allowed me to select the ODBC driver that worked for both file types.
I cameto realise that I was only having this problem on machines that have been upgraded to excel 2007 and not on machines with full virgin installations. On install both try to create the appropriate DSN but one with the same name already exists on the machines being upgraded and the creation fails.
I hope this helps others.
Excel merge to word office 2007
This might be an issue with the way you have your field set up.
Right-click on your field and select TOGGLE FIELD CODES until you can see the word "mergefield".
Assuming the name of your field is "mydatefield" , the code below should give you the required format.
{ MERGEFIELD mydatefield \@"DD/MM/YYYY" \*Mergeformat }
Good luck...
MS Excel 2007 SERIES function
First thing: Have yo downloaded *all* the updates available for Office 2007 from Windows Update?
Merging Data in 2 Separate Excel Workbooks
If the First Name and Last name are equal to both work sheets, I will just sort them by First Name and Last name and copy the results into a separate work sheet. If the names are different you will have to use Access: This can be easily done with Access and SQL, just import both work books into different tables to access and use the create query wizard, play with the results until you will get the result you want. Access will also solve the duplicate problem easily. Very important: You will have to use join properties: Read help about join properties and understand how this works... Afterward you can export it back to Excel or use Copy/Paste. If you can't use Access and have only Excel: You will have to use Vlookup on various fields until you will get the result you want. Its a hard work but in the end you will get the same result as access. Let me know what happend Daniel
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
