If you have the key, you can download office program here :
https://www.microsoft.com/en-gb/software-download/office and install. If you don't know the *********** then it will be a problem.
You can try finding *********** by a keyfinder tool :
https://www.magicaljellybean.com/keyfinder/
SOURCE: MS Office 2007 Installation issue -- need help with error message
this usually means it can't find the file on the CD/DVD, either the CD is dirty or bad, clean the disk and try again,
thanks for rating
SOURCE: MS Office 2007 Professional didn't install Outlook 2007
Try the Windows Installer Cleanup Utility, you can download it here
http://support.microsoft.com/kb/290301
SOURCE: Reinstall office 2007 small business
You can download the 60 day trial from the link below:
http://trial.trymicrosoftoffice.com/wwtrial/product.aspx?re_ms=oo&family=officesmallbusiness&culture=en-GB
If you have the product key, use it to activate Office and it will convert from a trail version to a full version.
SOURCE: Procedure how to establish aging of account receivable in excel
Once your data has been input into Excel - I assume you can do this via importing an outstanding debtors deport.
The easiest way I can see is by Pivot Table.
Your data should include open invoices and their respective due dates, it will be easier if you could covert these due dates into months - Create a pivot entering customer, outstanding values as your data and due months as your range.
SOURCE: scroll lock in excel 2007
When SCROLL LOCK is on, "SCRL" appears on the Excel status bar. If you press the arrow keys when SCROLL LOCK is on, you scroll one row up or one row down. Or, you scroll one column to the left or one column to the right. To use the arrow keys to move between cells, you must turn SCROLL LOCK off.
