Question about Acer Aspire 1690 Notebook
I have exactly the same problem with windows 7 anda an Acer 1691Wlmi with an ATI mobility radeon x600. When I uninstalled the ati drivers it became stable. When I reinstalled them the BSOD came back. Any answers? Any stable drivers?
5 Suggested Answers
Ekse
  • 13434 Answers
SOURCE: Driver for VGA ATI mobility Radeon igp 9000 for windows Millenium
You can get the correct driver from
http://support.acer-euro.com/drivers/notebook/tm_2000.html
Posted on Jan 08, 2009
Ekse
  • 13434 Answers
SOURCE: driver video ati mobility radeon 9000 igp for winme
The driver is available at
gambit3rogue
gambit3rogue
  • 106 Answers
SOURCE: i cannot install my graphic ati radeon hd3400 on windows xp
Requirements to properly install ATI Radeon™ HD 3400 series graphics card: an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable is required
Posted on May 29, 2009
Keynan
Ran Kedar
  • 977 Answers
SOURCE: Is a ATI Mobility Radeon X700 128MB Laptop Video
well... hard to say, given that ze4300 is a SERIES of laptops, therefore have a variety of model featuring different specifications. If it's the driver you need, you can download it HERE - compatible with Windows 2k/XP.
Hope I helped,
Pelu.
Posted on Mar 14, 2010
issken
Will Hartford
  • 1472 Answers
SOURCE: The ATI Radeon 3400 HD goes in an infinite loop
jrz3305
To bee able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Posted on Mar 29, 2010
Driver for ATI Radeon x600 128 mb DDR PCIe
ATI DRIVER SITE AT ATI.COM SELECT XP X86 32 BIT AND CARD INFO CELECT BEST ONE FOR YOUR Card
May 14, 2014 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Show video card Aspire 1691
I concur with Chris about this laptop model, (NOT that Chris needs me to concur)
If I may;
For the Aspire 1690 series of Notebook PC's, the graphics chipset is soldered directly to the motherboard.
There are models of laptops that DO indeed have a separate graphics, or video card. They use the MXM technology.
The Acer Aspire 1691wlmi Notebook PC, may have either the ATI Mobility Radeon X600 GPU, or the ATI Mobility Radeon X700 GPU.
(Graphics Processing Unit, or also known as the graphics chipset)
This is one example of the ATI Mobility Radeon X600 graphics chipset,
http://www.ebay.com/itm/1x-ATI-Mobility-Radeon-X600-216PDAGA23F-BGA-Chipset-/280796092668?pt=LH_DefaultDomain_0&hash=item4160c058fc
You are looking at a Top View, as it is mounted on the motherboard.
What you do not see is the method of mounting.
This graphics chipset is mounted to the motherboard, via a BGA surface mount.
Ball Grid Array.
To explain the BGA surface mount;
Compare to an older Intel Pentium 4 desktop processor, that uses a Socket 478 processor socket,
The processor has contact pins on the bottom of it's circuit board. 478 of 'em.
The processor socket has matching socket holes. (478),
http://en.wikipedia.org/wiki/Socket_478
With a BGA surface mount there are no contact pins, on the bottom of the graphics chipset, as used on an older Intel Pentium 4 processor. (That uses a Socket 478 processor socket)
There are no socket holes in a processor socket.
No socket on the motherboard.
In place of the contact pins, there are Solder Balls on the bottom of the graphics chipset.
In place of the socket holes in a socket on the motherboard, there are instead Copper Pads.
(The copper pads are also gold plated)
The graphics chipset is set down on the motherboard, with the Solder Balls lining up on the Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This action melts the solder balls, and solders the graphics chipset to the copper pads.
(Thereby also soldering the graphics chipset TO the motherboard)
This example of one maker, of a SMT/BGA Rework Station at work, will help demonstrate the above method,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll the page down, click on the red -
Take a few minutes to view the IR 650 demo video
That's just the mechanical aspects of replacing/upgrading a GPU, using a BGA surface mount.
Now you need to look into what will work.
The motherboard chipset determines what hardware components, can be used on a motherboard.
The motherboard chipset, as used on the Acer Aspire 1690 series of Notebook PC's, uses a Northbridge chip, and a Southbridge chip.
(Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Integrated Circuit, or chipset, that is used for graphics, is the graphics chipset, or G.P.U.,
http://en.wikipedia.org/wiki/GPU )
The Northbridge chip handles the faster capabilities of a computer.
Handles the Processor, Ram Memory, and High-speed graphics.
A graphics chipset using the PCI bus is NOT high-speed graphics.
(Such as a PCI graphics card inserted into a PCI slot, on a desktop computer motherboard)
Integrated graphics is also Not high-speed graphics.
High-speed graphics uses an AGP bus, or a PCI-Express bus.
The ATI Mobility Radeon X600, and X700 graphics chipset, on the Acer Aspire 1690 series of Notebook PC's, uses a PCI Express x16 bus,
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Mobility_Radeon_X300.2C_X600.2C_X700.2C_X800_Series
IF, your Aspire 1690 series Notebook PC, uses an ATI Mobility Radeon X600 graphics chipset, and you wanted to upgrade to an ATI Mobility Radeon X700 graphics chipset, it would not be worth your trouble.
By the time you buy the X700 chipset, have the X600 removed, and X700 installed, it would be cheaper, and wiser to just buy a better laptop.
[ One I bought for work to use on Electronic Technical Manual's, is an Acer Aspire 5552-3691
1) AMD Athlon II X2 P340 (Dual Core) processor
2) 4GB of DDR3 Sdram (SO-DIMM) ram memory at 1066MHz
3) ATI Mobility Radeon HD 4250 graphics chipset.
Price? $398.00USD.
Not the best by FAR. But MUCH better than what you have presently.
Just food for thought ]
Just thought you would like to know why, it isn't feasible to try to upgrade the graphics chipset.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 06, 2012 | Acer Aspire 1691WLMi PC Notebook
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
I have a acer x163w 13" monitor and I am trying to play call of duty 2 but keep getting the input not supported. How could I fix this problem so that I may play this game?
Call of Duty 2 Minimum System Requirements
3D hardware accelerator card required - 100% DirectX 9.0c compatible 64MB hardware accelerator video card and the latest drivers*
English version of Microsoft Windows 2000/XP
Pentium IV 1.4GHz or AMD Athlon XP 1700+ processor or higher
256MB RAM (512MB RAM recommended)
100% DirectX 9.0c compatible 16-bit sound card and latest drivers
100% Windows 2000/XP compatible mouse, keyboard and latest drivers
4.0GB of uncompressed free hard disk space (plus 600MB for Windows 2000/XP swap file)
8x speed CD-ROM or 2x DVD-ROM drive
Multi-player Requirements
Internet (TCP/IP) and LAN (TCP/IP) play supported
Internet play requires broadband connection and latest drivers
LAN play requires network interface card and latest drivers
Supported Chipsets
ATI Radeon 8500
ATI Radeon 9000
ATI Radeon 9200
ATI Radeon 9500
ATI Radeon 9600
ATI Radeon 9700
ATI Radeon 9800
ATI Radeon X300
ATI Radeon X550
ATI Radeon X600
ATI Radeon X700
ATI Radeon X800
ATI Radeon X850
nVidia GeForce 2 Ultra
All nVidia GeForce 3/Ti Series
All nVidia GeForce 4/Ti Series
All nVidia GeForce FX Series
All nVidia GeForce 6 Series
**Recommend nVidia GeForce 7 Series or higher
Do your PC support the above hardware requirements?
The most common input no support would be your graphic card is not up to the mark to play the PC games.
Is your graphics card drivers up to date to the latest?
Have you updated your DirectX to the latest version?
Hope it helps.
Apr 17, 2011 | Acer X193W LCD Monitor
I can't seem to find the driver for the ATI radeon x600 128mb PCI-e since the Catalyst Control Center wont install for me
download the updated driver from the lick given below...
for xp 32 and 64 bit
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-2_legacy_xp32-64_dd_ccc.exe
for win 7 32 and 64 bit
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-2_legacy_vista32-64_dd_ccc.exe
Dec 12, 2010 | ATI RADEON X600 SE 128MB DDR1 PCI Express...
ATI radeon x600 128 mb video (Windows 7) driver
AMD's DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. But you can install ATI Catalyst Windows Vista graphics driver under Windows 7. Some features may not be available under windows 7 but it would be worth a try.
Sep 27, 2010 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Hey, I have a hp zd8000 netbook with an ati mobility radeon x600 128mb video card i would like to know if i can run cod4 on it thx.
According to this you can't.
X600 Specs:
http://ati.amd.com/products/mobilityradeonx600/specs.html
COD4 System Requirements
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
Jul 05, 2009 | Dell RADEON X600, (128 MB) Graphic Card
I need to download ATI Display drivers for my Toshiba tecra S211 but i m not getting it on the net
ATI uses drivers called Catalyst Drivers. The ATI card you have is the ATI Mobility Radeon X600. Go to this link;
http://ati.amd.com/support/driver.html
Select your Vista or XP or whatever your Operating System is from the first list. Then in the second list, select mobiltiy radeon. Then Mobility Radeon X600 from the third list. Then click GO.
Then on the next page use the installation verification software. Once it verifys your hardware is compatible with the driver, it should download and install it.
Dec 19, 2008 | Computers & Internet
ATI Mobility Radeon X600 128MB Problems
Try restarting the pc in safe mode by tapping the F8 key while re-booting the computer. If the lines are gone it is the display driver.
You can get the correct drivers HERE from HP for your Laptop
Display problems support HERE
Jun 03, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Acer Aspire 1690 Notebook Logo
171 people viewed this question
Ekse
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
