Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
Anonymous Posted on Jun 22, 2008
Re: Kenmore Top Freezer formed ice, main refrigerator area is not cooling Kenmore Top Freezer (Main refrigerator area) is not cooling; This trouble shooting has happened for the past year. Main refrigerator area was either too warm or too cold and now, is not cooling period. A ***** of ice has formed in rear of the ice box. I removed ice maker and rear panel. Behind the panel was the unit/part that houses the refrigerant inside the aluminum piping and louvers. Ice was caked on throughout it. I just defrosted and cleaned every thing out. Please walk me through the rest of this trouble shooting process.By the way, is there an online video that will do just that? Thank you for your help and support Barry Adler [email protected] barryadler.com 310 828-2435
  • Anonymous May 06, 2009
    my kenmore with top freezer it is not cooling
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Jun 22, 2008
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898757
Points
3964
Not easy to diagnose. the basic fault is that the defrost system has packed up.
check that there is continuity thro the defrost heater. there may also be a thermal fuse in series with the heater so check that also.
if those ok, then points to a fault in the main module
I have a Kenmore top freezer. Every few days the freezer will get warm enough to cause the ice in the ice maker bucket to melt a little and then it will refreeze into a big block of ice when the...
Hi, It is sticking in the defrost mode...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Kenmore model# 79573966 - Top Freezer Ice is
heatman101
Ice forming in the top freezer, leaks in the bottom refrigerator section
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
Frost (ice)forms on back of freezer and the refridgerator area does not get cold. If I turn off for a few hours it works for a couple of days Thanks
heatman101
Why is my freezer bottom forming ice. andd leaing water
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Fridge is not cool
this is the problem of heater please replace it actually the matter is, behind the freezer panel there is a fan motor and behind it there is a coil in which the ice is formed. now the logic is, when the formation of ice increases then at that time the heater automatically defrost the ice this prevent from blockage of air pipe to the frizer.
Fridge not cooling
need to replace the defrost thermostat , heres some useful information, go to :
http://www.acmehowto.com/howto/appliance/freezer/check/defrosthermo.php
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
