The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This often
occurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the drive
configuration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has been
corrupted or deleted.
When your computer starts, the BIOS attempts to find the primary hard drive's active partition
to read the first sector for the MBR (Master Boot Record), it uses that info to
load the rest of the OS. For Windows NT4/2k/XP the MBR is pointed to the
NTLDR (New Technology
Loader) and it takes it from there. If you get the "NTLDR is missing,
press any key to restart" what's most likely going on is the BIOS either
didn't look for the right drive, didn't find the right partition, it
wasn't active, didn't find the MBR, or the MBR didn't list NTLDR in the
right place, the location of NTLDR changed, or you are looking at
a hardware failure situation
Solution
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that
contains Windows.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.
However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this and
use the Recovery Console to fix NTLDR manually instead.
How To: Fix "NTLDR is missing" Applies to: Microsoft Windows NT, Windows 2000, Windows XP When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart." The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted. First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows. If this does not resolve the problem, you will have to repair the NT boot loader. The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead. The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
NTLDR is short for NT Loader, which is software that helps to start your computer's operating system. If your computer says the NTLDR is missing, then your computer is attempting to boot up from a non-bootable source, or a drive that does not have NTLDR. Examples of non-bootable drives include CD or DVD drives and flash drives. To clear this error, remove non-bootable drives and reboot your computer. Also check the boot order in your Basic Input Output System (BIOS) to make sure your computer is starting properly One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faultyhis problem. hope this helps
Corrupted files, loose cables inside your computer and damaged hard drives also will prompt an "NTLDR Is Missing" error. If you continue to receive this error after multiple attempts to boot, then you may have one of these other problems and you will need to consult with a computer technician to troubleshoot t
