Posted on Nov 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need operating manual for epson 2580 scanner.
Anonymous
Level 2:
Sergeant:
Novelist:
  • Expert 191 Answers
  • Posted on Nov 15, 2010
Anonymous
Expert
Level 2:
Sergeant:
Novelist:
Answers
191
Questions
0
Helped
83103
Points
597
Following is a link to Epson support website. The link takes you directly to the online version of the operating manual for 2580 scanner.
http://files.support.epson.com/htmldocs/per248/per248rf/index.htm
How do you scan a slide on an epson 2580 scanner? It's scanning like a photograph not a slide.
You need the slide attachment, Read the Manual by clicking below.
Epson Manual
And the adapter should be included in the box which you purchased
Regards,
Ron
1helpful
Epson perfection 2580 scanner will not start. Programs installed w/cd. Epson updates added. Just says" scanner can not start"
The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
I hope this helps.
(scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
1helpful
I have an epson 2580 it now produces somewhat
The only way you're going to know if it's the scanner or the driver for sure is to install it on say an XP machine and see what results you get. If it's still dark, it's the scanner, if not, it's the driver.
My epson scanner 2580 photo won't do anything, it is connected
plz try by reloading the drivers then change the port and usb cable
1helpful
File settings dialog box is too high on screen to read, doesn't drag down
Go to the display properties of your computer and change the resolution.
Goodluck.
sherlyn c.
1helpful
How to scan a slide
Hi Arlene,
Have a look here:
http://files.support.epson.com/pdf/per248/per248bb.pdf
This is the quick reference card that would have been supplied with the scanner, scroll through the information to page 5 which tells you how to scan film or slides.
If you want the full manual and information then have a look here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=41624&prodoid=46253280
I hope that helps.
Mike
2answers
I need installer in this scanner
i dont have the cd for install the scaner (epson-2580 photo) please help me. thank.
Epson 2580 scanner
The only thing I can think of is to turn you to be scanned image up side down in the scanner bed.. IE Rotate 180' As another work arround simply open up Paint etc,and rotate the image 180' and save, ya should be all good.
k24674
ADMIN Andrew
ADMIN Andrew
