20 Most Recent
Epson Perfection 2580 Photo Flatbed Scanner Questions & Answers
I have an Epson Perfection
Please follow the steps below to resolve your issue:
1.Turn off the scanner.
2.Disconnect the USB or Firewire cable from the back of the scanner.
3.Disconnect the Accessory Interface cable from the back of the scanner.
4.On the left hand side of the scanner, you will see a transportation lock. Use a coin or similar flat object to lock and then unlock. Repeat this 3 times, ensuring the lock is back in the unlock position when finished.
5.Lift up the lid to the scanner. On the bottom left hand side, you will see a transportation lock that slides horizontally. Toggle this 3 times, ensuring that it is back in the unlock (left) position when finished.
6.Reconnect the USB\Firewire cable and the Accessory Interface cable and turn the scanner on.
7.If the error is cleared, please try scanning and all should be well.
Scanner tells me no scanner
Hi
It might be the scanner driver is corrupted, try to uninstall andreinstall the scanner driver again and then add again the scanner into the printer and faxes device.
Red flashing power light
I am sure the original poster will have probably replaced the unit by now but I just had a similar problem with my Epson Perfection 2480 Photo scanner so I think it is still worth posting the solution in case other people hit this problem in the future.
All I had to do was put the switch underneath the scanner to the "unlocked" position and then reboot the unit.
Hey presto it burst back into life.
It's annoying to see that the manual seems to suggest that the red light means the unit is "dead" !
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
