SOURCE: error code B200 on a
I searched for the error you posted. Cannon wants you to call them. (Weird but true). I'll past the message from Cannon.
Issue: ERROR LCD: Error code B200
Solution: Contact Canon for B200 error (MX850)
Canon has excellent service options and we are eager to provide any assistance you may need.
Please contact us through the email link or phone numbers listed below.
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
At least it's a free number.
Good Luck!
Mike
SOURCE: Error Code B200
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: What is error B200 on Canon MX850?
The B200 error is a Voltage High Error. I read that you should try using a different power outlet and see if that works and if that doesn't work try cleaning the print head:
If it doesn't fix it then the board inside of the printer is faulty and you will have to replace the printer
Thanks.
-Sa_Les_Ski
