My laptop turns it self off. I originally thought that it was because it was overheating, but I am not sure. I will be working on it and then poof it is off; it does not go through the shut down process; it just turns off. Please advise.
Try this take air can and blow the fan area out on the left side rear corner and the back area left rear to blow any dust or clog. and you should be straight.
Can you check the power cable is connected correctly and that the battery has sufficient power - laptops running on their batteries just switch off when the batteries are coming to the end of their useful life. E.g the batteries last bit of charge is not sufficient to warn the user that the laptop is shutting/needs to shut down.
Same issue! I keep a fan blowing on laptop the entire time its on. This keeps unit from shutting down on its own... Sucks!!!!!!!!!!!!!
