20 Most Recent
Averatec 3500T60 Tablet PC Questions & Answers
Dismantelling Averatec 3500 series tablet PC
I have this same laptop. It is pretty simple to tear apart. Is there any specific areas you wish to access or did you want to just take it completely apart? If you are going ofr the keyboard ribbon or the touchpad ribbon, just undo the two screws out that are located behind the pivot point of the screen, then open the laptop and remove the small plate. This reveals access to two more screws (2 silver, 2 black). Remove the silver ones not the black ones. The black screws remove the lower shell assembly. Once the silver screws are removed the accessory bezel can be removed. ( the one with the power button and lights)
There are yet two more screws that lock down the keyboard. Remove them and pivot the keyboard toward the touchpad. You can now safely remove the keyboard.
My tablet will not turn on ?
time to replace the adapter, you can take it to a best buy or a electronic store to be sure. ask then to test the laptop, with and adapter they might charge a fee, better to be safe than sorry
i figure an adapter last about 1-2 year depends on how you treat them.
If you do not take care of your electronics, your electronics will not take care of YOU!
I’m happy to help further over the phone at
https://www.6ya.com/expert/david_92c86cbc79e9b552
The Pen
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
The DVD drive for my Averatec C3500 does not eject.
First check the bios settings, set to the default settings.
You can dowload a bootable linux CD from here:
http://www.knoppix.org/ (I recommend the v3.3)
If you can use a cd with that it is a software problem.
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
