Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
Posted on Oct 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon pixma mx340 4-in-1 wireless printer thinks it's jammed when it's not. say "error 6000". Assistance is greatly appreciated. thank you
doubee
Level 2:
New Friend:
  • Expert 128 Answers
  • Posted on Nov 01, 2010
doubee
Expert
Level 2:
New Friend:
Answers
128
Questions
0
Helped
44926
Points
355
Error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1928
Points
I have seen inside the printer there is nothing paper jaam problem why it showing me error 6000 problem
2answers
My printer canon mx328 error 6000
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this mistake.
Canon Printer Error Code 6000 refers to something in the printer that interferes with the movement of the carriage. In any case, I've been able to locate the problem: a piece of torn paper on the left side of the printer. Hard to get there However it's likely. The printer is running again! But often this is induced by a software error. Foreign objects, such as dust spores, pieces of paper, sticks, stickers, or other objects, block the proper opening of the paper feed tray. Due to the jam, the printer has an error of 6000.
Reasons for Canon printer error code 6000: The printer feed tray is wrongly fitted. A huge volume of documents next to the printer. The line feed is scratched or coated. Offer several print commands on paper at once. Faults in the sensor unit or in-line feed slit.
Our service: 24/7 support with the Printer expert team.
Pixmama mx712 6000 error
Is this a brand-new printer? If so, make sure you haven't left any of the packaging materials inside the printer (any of the colored tape, foam, paper, shipping plastic pieces, etc.).
Make sure you don't have any empty cartridges, and that there's nothing jammed in the printer.
2helpful
Service error 6000 for canon pixma iP 1600
Error 6000
An error occurred in the LF encoder signal.
Can be the result of a deep paper jam with pins, paper or other miscellaneous objects stuck in there.
Check the unit and clean thoroughly.
2answers
My Canon iP4300 printer is giving me a service error 6000 message. How do I fix this problem.
Canon:
Sounds like you might have a paper jam. Sounds like there might be a piece
of paper, or a scrap torn from a piece of paper, stuck somewhere in the
paper path. The "peculiar sound" once you switch it on could be a clue that
there is a problem of that sort as parts that are not free to move properly
grind against one another.
Paper feed error [6000]
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
3helpful
4answers
I have a Canon MP 520 Pixma printer and getting error code 6000
There is got to be a paper Jam inside the printer OR
Look for something that might have stuck up the roller ..
Thanks
Fame !
11helpful
What is service error 6000?
You have a paper jam somewhere. Cannon printers are very sensitive to any small pieces of paper trapped in the rollers.
3answers
Error code 6000 on canon pixma mp210 stops me from printing
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this failure. There are several explanations why Canon Printer Error 6000 will happen when you work with a Canon printer. One of the factors is that one of the most simple common explanations is where the paper feed tray is blocked by certain dust particles and bits of paper. Another reason for this is that the paper feed tray is not adequately connected to the printer. If there is a tonne of a print order.
Reasons that cause Canon Printer Error Code 6000:
1. The feed tray of the printer is improperly fitted.
2. A large number of documents near the printer.
3. The line feed is scratched or smeared.
4. Giving multiple paper print commands at once.
5. Faults within the sensor unit or in-line feed slit.
Follow Blog: Canon printer error code 6000
Thanks for reading.
old marine
old marine
ZJ Limited
ZJ Limited
