Vivitar ViviCam 3750 Digital Camera Logo
Posted on Oct 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant find my instruction manual,,,,need to know how to review and delete pictures.. need to get new manual
Anonymous
Level 3:
Brigadier General:
  • Master 7,191 Answers
  • Posted on Oct 29, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
7191
Questions
Helped
1334946
Points
22939
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Thanks for using FixYa.
2answers
How do i delete pictures on sd780is canon
Go to menu, select pictures, run though menu for pictures tell you see delete
How can I delete individual images from my camera?
Press the review button to view your images. Navigate to the picture you wish to delete then press the delete button, it should look like a little rubbish bin. The camera will confirm the delete, so navigate to "yes" and hit [OK].
You should refer to your instruction manual for any further questions about using your camera and navigating its software.
Trying to delete pitchures from my sony cyber-shot
There is a button with a picture of a garbage can...this is the delete button and it works in review mode when you're looking at the pictures you've taken. Bring up the picture you want to delete and press that button...follow the on-screen instructions.
Sep 09, 2009 • Cameras
Deleting pictures from my camera jazz JDC31 Digital camera
Hi sjadl2840,
I presume you've already saved those pictures you want to keep in another location and you want to flush everything in the camera.
Typically, you have a button on the back with a little trash-can picture next to it. Pressing that will put you into Review/Delete mode. You will usually need to use the up/down/left/right arrow keys to navigate to select the photos you want to delete. Selecting the "OK" or "select" button will select that photo for deletion. You will typically have to confirm deletion for each photo, or before deleting all (if your camera provides that option in it's programming).
These instructions are somewhat generic; if they don't work for you, respond with a comment, and we can zero-in on your specific situation.
Beyond that, if I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
2answers
Picture error
I would recheck all of my settings on the camera. Go to the menu and check everything one by one. Your card may be damaged also. Do you have another card to try? Do you have your manual? If not you can to to www.olympus.com to download a new manual specifically for your camera and it may address this issue. Good luck.
1helpful
How to delete a picture
Slide the upper-right slide switch down to put the camera in picture review mode. Press right or left on the circular switch to find the particular picture you want to delete. Then press the upper left "trashcan" button to delete.
To erase ALL the pictures, leave the camera in picture review mode and press the menu button. The erase command should be around the fourth item listed in the menu that pops up.
When done, don't forget to slide the upper-right switch up to put the camera back in picture taking mode.
2answers
Hi i would like to know how to delete pictures from my CANON DIGITAL POWERSHOT SD 850 IS camera.
If it's anything like my A620, go into Review mode (there should be a switch between a camera picture and a triangle play icon - you want the triangle), and navigate to the picture you want to delete. Then press the button with the trash can next to it.
Apr 07, 2008 • Cameras
Cant figure out how to delete photos
Have you loaded the software that came with the camera?
Do you have the usb cable to connect the camera to the computer?
Are you using internal memory or an SD card?
If you do not have the user manual go to this link
http://www.polaroid.com/service/userguides/digital/cameras/i532_ug_en.pdf
To get to the pages below:
Left click on the page number next to the right arrow and put the page number you want in and hit the enter button the the keyboard.
On page 4 of the user manual #6 Manager Pictures and Video Clips you have a selection
Go to page 54 of user manual it shows you in detail how to review your pictures.
JUST A NOTE
The cameras internal memory is very small, you will need an SD card Page 28 in the manual
Any other problems, let me know
Mar 27, 2008 • Cameras
New camera, no manual
oh, thats simple, all you do is go to the review your photos (to do that you click the small rectangular button that has a green arrow above it, and that will bring you to review your photos)
from there you want to press the down button and a menu will appear, go up to delete and click on it, then delete it
hope that helped!
2answers
New camera
to download it uneed a USB or UBS cord..[i forgot]
to delete press down button...or click on the the menu button to review pictures and then press mode then press delete all..
in the front front of your camera is a picture of a flower & a mountain with a person ..if u slide it to theside with the flower then that is no flash...and the mountain is flash!!
well that i could help you with right now!!
Oct 22, 2007 • Cameras
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
