20 Most Recent Vivitar ViviCam 5385 Digital Camera Questions & Answers
Vivitar might have a solution but we do not
Vivitar ViviCam... | Answered on Dec 05, 2017
I have a Vivitar 7340 and i would get the lens error 1114 and it would shut off. with the camera off and the lens full out. i turned the back and forth with a little force. turned the camera back on and it works great
Vivitar ViviCam... | Answered on Sep 01, 2016
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
Vivitar ViviCam... | Answered on Apr 22, 2016
IR/ night vision, Black and white also seem to work good most of the time too. Just keep playing around until you find one that suites your needs. Happy refraction !!!!.
Vivitar ViviCam... | Answered on Apr 03, 2015
The 5385 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards such as your 16GB card.
Vivitar ViviCam... | Answered on Mar 20, 2014
Does your laptop happen to be a Mac? But no matter. You can still use your laptop to recover your photos with recovery software. Here's several freeware for PC's, but it also includes a link to one freeware for Macs just in case my guess was right. Seem to see this particular problem occurring frequently (corrupted card after plugging into computer), but primarily occurring with Macs, and also gaming systems such as Wii.
Now to get the card working again, after recovering your photos, you'll need to format the card in your camera using the cameras format feature. If the camera does not recognize the card, you'll need to format it first in a PC to FAT32, then reformat again in your camera.
Vivitar ViviCam... | Answered on Nov 19, 2013
Having gone over ten months without a response to my query, I assume my suggestion to use a card reader instead of a cord solved the problem.
Vivitar ViviCam... | Answered on Sep 05, 2013
The camera uses standard SD cards, 2GB or smaller, which should be available at just about any department, electronics, or office-supply store.
Vivitar ViviCam... | Answered on Mar 12, 2013
Your pictures may be corrupted.You can recover those corrupted pictures with this
1. Do not save any new pictures into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
How to Recover Deleted Pictures from Digital Camera's Memory Card?
Vivitar ViviCam... | Answered on Feb 09, 2013
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Vivitar ViviCam... | Answered on Dec 19, 2012
This video illustrates troubleshooting steps for a lens error:
Vivitar ViviCam... | Answered on Dec 14, 2012
Dear June,
Yes, you might be correct. The cord may be faulty. Take out the memory card and insert it into a memory card reader. Then connect the card reader to your computer and see whether you can download the photos.
Vivitar ViviCam... | Answered on Oct 19, 2012
Vivitar ViviCam 5385 Digital Camera Logo
227 questions posted
Top Vivitar Cameras Experts
Ekse
Barbat Nae
Barbat Nae
Damen Wong
Damen Wong
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
vivitar 5385 when try download photo
  • Cameras
