Televison & Video Logo
Posted on Jun 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pt5499hd akai Hi, My tv became unfocus. It has 2-3 different color ghost images (red, blue, green or something like that). It used to have the auto focus come on and bring the images together. But now, the auto focus comes on for a little bit an goes out. I try to manual focus it, by pressing the focus button but it try partly and goes out. What is wrong and how can I fix it? Help. thanks thang
  • Anonymous Jun 20, 2008
    hi i have a zenith r56w36 crt projection tv. the red is casting a rainbow type effect sort of ghosts of the words and stuff at the bottom.when i turn the red color off inside the tv it goes away and picture is great,but no red in color.so what can i do?can you tell me where the board is located in my tv?and can i just replace the whole board instead of parts?
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Jun 03, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
22
Helped
1063615
Points
7105
It looks like you may to replace the convergence units. It will require repair.
3helpful
2answers
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Ghosting of the image
*Screen Looks 3-D
*Colors wont align
Problem #2
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
1helpful
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
AKAI PT5499HD
hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
thanks
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Akai pt5499hd
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
3answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
