Comment by JIMSHX46, posted on May 23, 2008
I have a BOSCH SHX46A07UC that won't STOP draining. Draining is all that it is doing presently. I recently had to replace the disposal and indoing so I failed to knock out the drain plug where the dishwasher drain hose attaches to the disposal. Unfortunately I ran the dishwasher and it could not drain. I realized what the issue was well after the cycle should have been complete. I opened the drain in the disposal and the water drained out of the dishwasher just fine. Now it wont stop draining. Can anyone tell me what I probably broke this time? Thanks in advance!
Take your dishwasher out and look for a water at the base of your dishwasher.
If that is a water at the botton base, just dry the water and its ok.
if you dont find water at the botton base inside replace the water level system PN= 263834 at repairclinic.com, item# 935595 for 41.00 and that part goes in the left side of your dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
The dishwasher won't stop draining at the start of the cycle. I have tried pouring in buckets of warter but it just drains it out.
