When attempting to change the password, instructions tell me to enter current password and press and hold # key. Opener light should blink 4 times. Light doesn't blink, but door opens. If I let door close completely, I am unable to open the door using the keyless pad. I am unable to change the password. Can you help?
Easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
Forgot password and cant change nothing works
I took a ladder went up and pushed the learn button once. The light comes on steady, then go to the remote and put in the 4 digit code you want and press enter. That's it, it worked.
In Canada Chaimberlain has a really helpful telephone line with an IVR
that does get you to the fix quickly. And it did solve my issue
with the remote. My problem was the previous owner of the house
did not leave the code. The basic steps were.
1. Make sure the battery is good.
2. On the motor unit of the actual garage door opener press the learn
button, mine was under a white plastic bulb cover that I had to remove.
3.While the learn button LED remains on for 30 seconds, on your keyless
remote type in your four didget code that you want and then hold down
the enter button for 5 seconds.
4. The light on the motor unit then started to flash confirming it had learned the code from the keyless remote.
5. Try the keyless remote by pressing your four didget code, then pressing enter. Your door should work.
To the guest's question. normally on liftmaster products you need to hold the 'learn' button on the back of the operator for 8-10 secs (till the led goes out). Then have all your remotes and keypad handy and reprogram them all. Push the button on the back of the unit then one of the remotes (1-2 sec) light will flash. Then repeat for the keypad press button and go enter your 4 digit code and hold enter 1-2 sec.
You can download the re-set instructions here:
Liftmaster 971LM Programming Instructions
LiftMaster 976LM Security+ Wireless Keyless Entry System
Hi Syls
Click HERE to view the online manual.
Is the buttons flashing the required two times once you've held in the # key ?
Try setting up a temporary pin first and then changing it back to a normal one again.
Let me know once you've tried it please.
Hi Syls
I think that the keypad is faulty and will most probably need replacement because it is not even flashing the same number of times when you enter the new pin either standard or temp. mode.
Hi Syls
Have you tried switching off the power for 12 hours and then retrying the procedures yet ? This should do a hard reset wich might just do the trick.
The power should in other words be shut off completely.
Enter first the default password. default password is listed in manual, I think it is 1234
This might be a helpful website for you
http://www.aaaremotes.com/liftmaster.html
Download programming instructions
Download
Programming instructionsl
Mine is model 940CB. I already have the instructions--they simply don't work.
I have the printed instructions. They simply don't work. Yes, I did try setting up a temporary pin first and that too doesn't work.
I already have the programming instructions. They simply don't work.
Thanks! I'll give this a try.
I tried your suggestion and it didn't work.
I'm still looking for a solution rather than a new purchase. Thanks anyway.
Previous owner left with code to keyless entry. How do I reprogram pad?
Exactly the same issue
bought a bank repo so no one knows the old code to enter so I can change to a new code.
