20 Most Recent Chamberlain Clicker Universal Remote Control KLIK1U Questions & Answers
0answers
I am following the directions. I have tried button #1 and #2. My garage door opens at 2 ft. I hit the button again it goes another 2 ft. and so on each 2 ft. it will close properly . Whats the deal ??
as it requires extra power to lift the door, it may be overloading on the current setting.check the wires and connections for the full up micro switch as it may be playing up as the door comes up.
5/5/2015 5:22:34 AM • Chamberlain... • Answered on May 05, 2015
How do I get distance from opener will only open whenupclose?
Has it always been that way, or just recently. Most garage doors will open for about 100 or 200 feet away. If it just started, you can replace the remote battery. Hope this helps.
2/25/2015 8:06:48 PM • Chamberlain... • Answered on Feb 25, 2015
2answers
My garage door remote opener died. Put in new battery, and light went on but it still doesn't open the door. Help?
You might have to reprogram the remote to sync up with the opener. The instructions will be in the owners manual. Some have a button on the rear or side of the motor unit you push while pressing the remote. The sequence is critical to the unit learning the remote code.
1/12/2015 5:54:31 PM • Chamberlain... • Answered on Jan 12, 2015
Clicker klkj won't work
Here is the video that will show you how to do it! https://www.youtube.com/watch?v=MxxgSTOePY8&feature=youtu.be
11/23/2014 3:42:16 PM • Chamberlain... • Answered on Nov 23, 2014
If then battery has to be replaced in the CLICKER key pad made by Chamberlin do you have to reset the code?
You should not have to reset the code. Simply remove the old battery and insert the new one, being careful to observe the polarity when you replace the new battery, and you should be good to go. The batteries can be obtained at most Wal-Marts, Radio Shacks and even through eBay if you know the correct number. Thay are lithium and will last a few years under normal use.
11/23/2014 3:38:16 PM • Chamberlain... • Answered on Nov 23, 2014
If I have a genie pro and am trying to program a universal remote - how many times do I need to click the remote to pair it with my garage door opener?
Is the garage remote infra red or radio? Does the universal remote support both modes of operation? If it's infra red then simply follow the programming instructions for the universal as normal. If RF then you may need another type of universal remote control that supports RF modes
10/14/2014 7:45:16 AM • Chamberlain... • Answered on Oct 14, 2014
How do I reprogram a clicker?
Erase all remotes (usually similar procedure to programming, but hold the button longer) from the door you don't want (it's on the opener/receiver, not the clicker) then program only the one you want.
9/30/2014 3:50:08 PM • Chamberlain... • Answered on Sep 30, 2014
Which battery fits the klik1
9794ab54-97c4-47b9-a70d-1040f5a1e84e.jpg you can find them almost everywhere
9/1/2014 4:33:48 AM • Chamberlain... • Answered on Sep 01, 2014
How to replace battery?
the front bottom slides down, from just under the buttons
9/1/2014 4:27:11 AM • Chamberlain... • Answered on Sep 01, 2014
Unable to program universal opener with genie pro max garage
Actually, this remote can be used with Genie Garages. See the article here on eHow - I used this to program a KLIK1U to work with my Genie Promax 2 garage. Hope that helps!
7/18/2014 4:23:01 AM • Chamberlain... • Answered on Jul 18, 2014
Why does the LED light not come when pressing the program button, Battery is good.
Are you holding the program button until the light comes on?
6/27/2014 12:36:58 AM • Chamberlain... • Answered on Jun 27, 2014
Another remote triggering my opener....
Change the code. Some one near has clicker with same code.
4/30/2014 4:26:14 PM • Chamberlain... • Answered on Apr 30, 2014
0answers
Chamberlain Clicker Universal Remote Control KLIK1U Logo
108 questions posted
Top Chamberlain Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Chamberlain Home Security
Most Popular Question
reprogram clicker
  • Home Security
