20 Most Recent Universal Garage Wireless Keyless Entry System Questions & Answers
Followed Clicker KLIK2U instructions meticulously
Contact the manufacturer with your problem ON LINE. They might be able to help you.
7/17/2016 5:48:49 PM • Universal Garage... • Answered on Jul 17, 2016
6answers
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
12/26/2014 11:36:14 PM • Universal Garage... • Answered on Dec 26, 2014
None of my codes work
Has your KLIK2U worked for your garage door opener before, or are you configuring it for the first time?
If it is being installed for4 the first time, are you certain you garage door opener was manufactured after 1993 & uses a photo-eye sensor? If not, the KLIK2U may not be compatible.
You may find the Chamberlain KLIK2U Digital Manual and the Chamberlain KLIK2U Programming Video helpful.
For more assistance from us, please provide more information about your garage door opener, and we may be able to help you through the programming instructions from the manual.
I hope that helps.
_______________________________________
Chamberlain KLIK2U Manual Download
12/17/2014 7:21:51 PM • Universal Garage... • Answered on Dec 17, 2014
Will this work on a martin door?
If the mechanism or motor that lifts the door says martin on it, then no. That opener is made by marantec. This is not compatible with the typical universal keyless systems. Marantec will have a product that is compatible. Another way is to buy and install a reciever kit and then the universal keyless will work.
5/24/2014 1:51:17 AM • Universal Garage... • Answered on May 24, 2014
Code for guardian model 628
can not close garage door keep beep
11/12/2013 7:49:53 AM • Universal Garage... • Answered on Nov 12, 2013
Program clk1
Follow the link to the programming instructions for your CLK1. http://www.lilocksmith.com/instructions/PDF_Files/LM_CLK1.pdf
9/20/2013 7:53:10 AM • Universal Garage... • Answered on Sep 20, 2013
3answers
Clicker KLIK2U Universal Keyless Entry
www.smarthome.com/manuals/7198.pdf
11/25/2012 7:28:14 PM • Universal Garage... • Answered on Nov 25, 2012
2answers
Can a Clicker Model KLIK1U Compatable with a
If you go to this site you will find a programming video and a down loadable owners manual. Should help you out.
http://www.chamberlain-diy.com/doityourself/pages/productmodeldetail.aspx?modelId=1477
10/17/2011 5:45:08 PM • Universal Garage... • Answered on Oct 17, 2011
I have gone throught the
I spoke to Overhead directly and they indicated that the HomeDepot Klick remote doesn't work with the older Overhead versions. They sold me a remote that worked for a cheaper price so I should have checked with them in the first place.
Now I'm happy after several days of frustration!
6/23/2011 10:00:53 PM • Universal Garage... • Answered on Jun 23, 2011
When I open the garage
This sounds like the spring coil has come disconnected you can check this by trying to open the door manually if it is really heave then the springs arent doing there job.
6/17/2011 3:54:28 AM • Universal Garage... • Answered on Jun 17, 2011
Lift Master Professional 1/3 hp
does the wireless keyless entry have batteries
1/28/2011 9:33:01 PM • Universal Garage... • Answered on Jan 28, 2011
2answers
Remote Clicker Model No. KLIK 2 can not be
If you follow the watch the video and follow the instructions on this site and still cannot get your opener to program then you have a bad logic board.
http://www.chamberlain-diy.com/doityourself/pages/accessoriesmodeldetail.aspx?modelId=1478
10/24/2010 6:18:41 AM • Universal Garage... • Answered on Oct 24, 2010
I have a clicker model
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
9/23/2010 4:44:15 PM • Universal Garage... • Answered on Sep 23, 2010
Where is the smart learn button on my Overhead
You do not have one. Just went through that myself! Tried differant universals none worked! Must buy the 109130-390
9/18/2010 10:10:58 PM • Universal Garage... • Answered on Sep 18, 2010
2answers
How do i program KLIK2U remote to my chamberlain
Check out this site. A video and an owners manual.
8/12/2010 3:29:49 PM • Universal Garage... • Answered on Aug 12, 2010
Need installation instruction of an old remote
KLIK2 Programmming Instructions. PDF file
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A3484.pdf
8/12/2010 3:28:29 PM • Universal Garage... • Answered on Aug 12, 2010
We have installed a chamberlain wireless keyless
We have a Chamberlain Whisper Drive Plus. The keyless entry stopped working, suddenly. I have changed the battery, not the problem. I cannot get it to work, and cannot get it to reprogram. The keypad lights up when buttons are pressed, but when I press "Enter" the whole keypad flashes for about 30 seconds and then just goes dark.
7/2/2010 1:28:45 AM • Universal Garage... • Answered on Jul 02, 2010
Klik2u purchased. Have Challenger Door opener with
UNLESS THE KIK2U HAS A UNIVERSAL RECEIVER IT PROBABLY WON'T WORK WITH CHALLENGER - VERY FEW UNIVERSAL SYSTEMS DO.
GET A CHAMBERLAIN / LIFTMASTER / CRAFTSMAN UNIVERSAL SYSTEM THEY HAVE A RECEIVER AND REMOTE / KEYLESS THAT WILL WORK WITH THE VISOR SYSTEMS IN CARS AND IS VERY EASY TO USE AND RELIABLE.
HOPE THIS HELPS
6/23/2010 2:15:02 PM • Universal Garage... • Answered on Jun 23, 2010
2answers
Garage door closes then goes up immediately, has
Hi. Remove the cover on the motor and you will find the up and down adjustment screws and the pressure adjustment screw. Begin by turning the down screw in one turn and check to see if that solves the problem. write down the adjustments you make so you don't forget. Also make small corrections, one screw turn, and then test it. Joe.
5/30/2010 10:13:14 AM • Universal Garage... • Answered on May 30, 2010
Universal Garage Wireless Keyless Entry System Logo
139 questions posted
Top Universal Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Universal Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Universal Building Materials
Most Popular Question
clicker model klik1u compatable
  • Building Materials
