This indicates the keypad or ERC electronic range control has failed. 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Try this linkhttp://appliancehelponline.com/ovenerc.h...
you don't need a "professional" to solve this problem or even to order any parts. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser (see -http://www.fixyourboard.com/techzone/ove... - for illustration), reinserting it into the slot and repeat above with the paper. good luck.
This worked like a charm!!! I did it
