SOURCE: How to change the answering maching message
Depending on how your automated attendant is programmed, you will need to either change certain prompts or certain Custom Service menu greetings. Without knowing how your system is configured, I can't be more detailed, sorry. However, we can fix this for you over the Internet with our remote support package...
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
SOURCE: panasonic kx-tg2740 cordless phone - how to change message?
i found this i hope it helps
SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
SOURCE: I have a kx-tda30 unit
A couple of things come to mind, but what happens when you press PROG and the line 1 button on an idle phone? If it doesn't say Single Line-001, that could be something. Dial 0 01 and press ENTER. Now CO1 is back under that button.
The other items deal with line preference incoming so save it for later.
Carl
